[mapserver-users] GetFeatureINFO errors in Mapserver not
occurringin Geoserver.
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Apr 23 17:11:41 EDT 2009
Sounds like more of an SDE problem than WMS. Can you query the SDE layer
outside of WMS just
using MapServer queries?
Steve
>>> On 4/23/2009 at 3:59 PM, in message
<1240520397380-2686390.post at n2.nabble.com>,
Michelle Douvil <mrdouville at shaw.ca> wrote:
> We have data that is in Oracle 10.2.0.2 Enterprise
Edition with ArcSDE 9.1
> General Update Patch 3.
> We have several spatial views that are causing us issues when
GetFeatureINFO
> is requested via Mapserver 5.2. The result is an SDE error.
> SE_stream_fetch_row(): Invalid parameter value passed to function.
(-66).
> However, using Geoserver 1.7.3 to the same data the GetFeatureINFO
request
> is successful. Any thoughts as to why Mapserver has issues but
Geoserver
> does not?
> The Spatial View given in the example below is a simple view (no
where
> clauses or join statements). We have re-registered the Spatial view
with the
> sde to make sure the objectid was correct.
> Looks like Geoserver 1.7.3 doesn’t mind GetFeatureINFO on
> SCHEMA.AEI_AIR_QUALITY_AOI_SVW
> Whereas Mapserver 5.2 gets confused.. see examples below
http://server/geoserver/wms?service=wms&request=getFeatureInfo&version=1.1.1&la
yers=prod:AOIAEI&query_layers=prod:AOIAEI&width=500&height=500&SRS=EPSG:4326&BBOX=
-126.94250575451,54.5026638549918,-126.72424645805,54.6394718590618&x=200&y=200&
> info_format=text/plain
> Results for FeatureType 'AOIAEI':
> geometry = [GEOMETRY (Polygon) with 22 points]
> air_quality_aoi_id = 66
> aoi_name = Bulkley Valley / Lakes District
> status = Plan Established
> feature_code = FF00595000
http://server/mapserver/air-climate?service=wms&request=getFeatureInfo&version
=1.1.1&layers=AEI_AIR_QUALITY_AOI_O&query_layers=AEI_AIR_QUALITY_AOI_O&width=500&
height=500&SRS=EPSG:4326&BBOX=-126.94250575451,54.5026638549918,-126.7242464580
> 5,54.6394718590618&x=200&y=200&info_format=text/plain
> GetFeatureInfo results:
> Layer 'AEI_AIR_QUALITY_AOI_O'
> Content-type: application/vnd.ogc.se_xml
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException>
> msSDELayerGetShape(): SDE error. SE_stream_fetch_row(): Invalid
parameter
> value passed to function. (-66)
> </ServiceException>
> </ServiceExceptionReport>
> many thanks for any assistance.
http://n2.nabble.com/GetFeatureINFO-errors-in-Mapserver-not-occurring-in-Geos
> erver.-tp2686390p2686390.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
