[mapserver-users] Refresh map after database change
Ganaël Jatteau
gju at galigeo.com
Mon Aug 3 10:59:50 EDT 2009
Hello,
Sorry, Im not sure this message should belong to the mapserver list since
it tends to be more like a Fusion issue.
I use Fusion to display a map (with mapserver) that gets its layers from
PostGIS.
I do change some shapes in the database, then I call
Fusion.getWidgetsByType(RefreshMap)[].execute() to refresh the map (in
order to display the new data).
The interesting thing is that the refresh takes the changes into account
when I run a browser locally on the machine where Apache Mapserver is
running but not from another machine (in both cases, the map disappears then
re-appears on the webpage)
I tried to introduce a sleep at the end of the code that updates the
database to make sure its not a timing problem. I also tried to use two
exact same versions of Firefox, but no result.
However, if I zoom/unzoom I can see that the change has been applied.
Any idea? Thanks in advance.
Cheers,
Ganael
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090803/ef86678d/attachment.html
