[mapserver-users] Too Many Open Files
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Aug 12 10:50:19 EDT 2009
Daniel,
I haven't worked with TomCat, but if it doing something like creating a
process/thread/whatever for the mapscript request but treating it like a
reusable thread, then it might not be shutting it down in which case
files are not getting closed. The user might need to make sure TomCat is
treating this like a cgi-bin process and not a mod_* type of process.
-Steve W
Daniel Morissette wrote:
> aseem wrote:
>> Thanks Daniel. Thanks for the reply. Yes, We are using MapScript.
> PHP MapScript?
>> I have
>> checked the open files by executing lsof command. I found that most of
>> the
>> files are related to FGS. Following is the part of the output we got
>> after
>> running lsof command.
> You seem to have two processes with each about 30-40 files open, mostly
> shared libraries. That's nothing to worry about or to take a system down.
> Perhaps you need to re-check after 20-30 minutes of operation, when the
> web server locks up (this is what happens, right?). What we're looking
> for is an indication of a leak of file handles, i.e. the same file
> opened hundreds of times... then we'll need to find out why that file is
> never closed.
> Which error message did you get exactly that led you to think that there
> was a problem of too many files opened? Does the same problem happen if
> you connect directly to the instance of Apache that comes with FGS
> instead of going through the Tomcat server?
> Daniel
