[mapserver-users] WFS: msMSSQL2008LayerGetShapeRandom bad
shape: 1
D Boyd
davidboyd at ntlworld.com
Thu Aug 13 07:45:03 EDT 2009
Hi Tamas,
Thanks for the quick reply, I grabbed the new binaries but am now getting a
different error. The request seems to terminate while the error log is being
written do its now showing what is causing it. The page returns the "The
specified CGI application misbehaved by not returning a complete set of HTTP
headers" error message.
Any help would be greatly apreciated!
[Thu Aug 13 12:31:55 2009].204000 CGI Request 1 on process 2064
[Thu Aug 13 12:31:55 2009].204000 msMSSQL2008LayerOpen called datastatement:
PointPos FROM Points
[Thu Aug 13 12:31:55 2009].204000 MSMSSQL2008LayerOpen -- shared connection
not available.
[Thu Aug 13 12:31:55 2009].290000
msConnPoolRegister(PointData,connectiondata)
[Thu Aug 13 12:31:55 2009].290000 msMSSQL2008LayerRetrievePK: query = SELECT
convert(varchar(50), sys.columns.name) AS ColumnName, sys.indexes.name FROM
sys.columns INNER JOIN sys.indexes INNER JOIN
sys.tables ON sys.indexes.object_id = sys.tables.object_id INNER JOIN
sys.index_columns ON sys.indexes.object_id = sys.index_columns.object_id AND
sys.indexes.index_id = sys.index_columns.index_id ON
sys.columns.object_id = sys.index_columns.object_id AND
sys.columns.column_id = sys.index_columns.column_id WHERE
(sys.indexes.is_primary_key = 1) AND (sys.tables.name = N'Points')
[Thu Aug 13 12:31:55 2009].290000 msMSSQL2008LayerParseData: unique column =
PointID, srid='0', geom_column_name = PointPos, table_name=Points
[Thu Aug 13 12:31:55 2009].290000 msMSSQL2008LayerGetExtent called
[Thu Aug 13 12:31:55 2009].290000 msMSSQL2008LayerFreeItemInfo called
[Thu Aug 13 12:31:55 2009].290000 msMSSQL2008LayerClose datastatement:
msConnPoolRelease(PointData,connectiondata)
[Thu Aug 13 12:31:55 2009].290000 msConnPoolClose(connectiondata)
[Thu Aug 13 12:31:55 2009].321000 msMSSQL2008LayerOpen called datastatement:
[Thu Aug 13 12:31:55 2009].321000 MSMSSQL2008LayerOpen -- shared connection
not available.
[Thu Aug 13 12:31:55 2009].330000
msConnPoolRegister(PointData,connectionData)
[Thu Aug 13 12:31:55 2009].330000 msMSSQL2008LayerRetrievePK: query = SELECT
[Thu Aug 13 12:31:55 2009].331000 msMSSQL2008LayerParseData: unique column =
[Thu Aug 13 12:31:55 2009].331000 msMSSQL2008LayerFreeItemInfo called
[Thu Aug 13 12:31:55 2009].331000 msMSSQL2008LayerWhichShapes called
[Thu Aug 13 12:31:55 2009].331000 query_string_temp:SELECT
PointPos.STAsBinary(),convert(varchar(20), PointID) from Points WHERE
PointPos.STIntersects(Geometry::STGeomFromText('POLYGON((-1000000
-1000000,1000000 -1000000,1000000 1000000,-1000000 1000000,-1000000
-1000000))',0)) = 1
[Thu Aug 13 12:31:56 2009].966000 msMSSQL2008LayerFreeItemInfo called
[Thu Aug 13 12:31:56 2009].966000 msMSSQL2008LayerClose datastatement:
[Thu Aug 13 12:31:56 2009].966000 msConnPoolClose(connectionData)
[Thu Aug 13 12:31:56 2009].967000 msMSSQL2008LayerOpen called datastatement:
[Thu Aug 13
You've probably run into the same problem which I've already fixed (in trunk
and branch-5-4) 2 days ago.
For more details see:
http://trac.osgeo.org/mapserver/ticket/3082
Windows binary packages (containing the fix) can be downloaded at:
http://vbkto.dyndns.org:1280/sdk/Default.aspx
Best regards,
Tamas
View this message in context: http://n2.nabble.com/WFS%3A-msMSSQL2008LayerGetShapeRandom-bad-shape%3A-1-tp3431353p3437352.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
