[mapserver-users] Scaling Image Symbol Offset
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Aug 13 10:39:54 EDT 2009
Hi David: There is no connection between offset and symbol size. The offset is independent and given
as a constant value in pixels (although it is scaled). Sounds like you need to change it dynamically based
on your image size and that can't be done as things sit now. Can you fix your image size or is it and I'm
missing something.
Steve
>>> On 7/16/2009 at 3:51 AM, in message
<9C37154DC7C8074FBC34214363755B7C33087F at ITB-SVR-01.itbeyond.local>, "David
Martin" <David at itbeyond.com.au> wrote:
> I am developing a new application and am rendering around a load of
> graphic symbol layers using a Map file layer such as
> LAYER
> NAME cape_headland_point
> STATUS ON
> GROUP all
> DATA 'ExplorOz/Places/Cape,Headland,Point'
> TYPE POINT
> SYMBOLSCALE 1000000
> CLASS
> STYLE
> SYMBOL [POIImage]
> MAXSIZE 15
> MINSIZE 4
> SIZE 8
> END
> END
> METADATA
> "wms_title" "Capes, Headlands & Points"
> END
> PROJECTION
> "+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs"
> END
> END
> As you can see I am sizing the output symbol which is a 20x20px PIXMAP
> image - this is working great however the position of the image needs to
> be OFFSET up by half the size of the image (to make the actual point be
> the center of the image) - I have tried using OFFSET however when the
> image size changes (based on SYMBOLSCALE)the offsets are wrong. Is there
> a way to OFFSET image symbols based on the SYMBOLSCALE and MAX/MIN
> SIZES?
> Regards
> David
