[mapserver-users] Tileindex and drawing order of overlapping
images
Frank Warmerdam
warmerdam at pobox.com
Fri Aug 14 08:23:52 EDT 2009
On Fri, Aug 14, 2009 at 7:37 AM, Rahkonen
Jukka<Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> If have overlapping images from different years. Can I control in some
> easy and reliable way that the new images will get drawn on top, for
> example by writing tileindex shapefiles so that new images have bigger
> fid values?
Jukka,
The order of images in the tileindex shapefile will be the order
they are drawn - if - you do not build a spatial index on the
shapefile. If you have a spatial index the drawing order
becomes essentially random, and of course if you have a lot
of images a spatial index is quite valuable.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
