SV: SV: [mapserver-users] Mapserver consuming Google Maps
Till Adams
adams at terrestris.de
Wed Aug 26 04:17:06 EDT 2009
Niels-Peter,
the features you mention (turning on/off layers, changing order of
layers) are for me more client side features than serverside- or
mapserver-features - which brings us back to the client... ;-)
If you are looking for a free basemap you may check openstreetmap (OK,
no aerial images so far, but also in progress:
http://wiki.openaerialmap.org/OAM_2009 )
Regards, Till
> Hi Till
> I see the google maps tiles as a way of getting a free basemap. You are
> properly right regarding distroted labels when reprojecting googlemaps -
> depending on where you are in the world and the final projection. But at
> least a pure sattelite image would ok.
> I could make a client to consume both Mapserver and Googlemaps, but I would
> like to do it on the server side and be able to use MapServer features, eg.
> turning on/off layers, changing order of layers and so on.
> Regards Niels-Peter
> -----Oprindelig meddelelse-----
> Fra: Till Adams [mailto:adams at terrestris.de]
> Sendt: 26. august 2009 09:21
> Til: Niels-Peter Jensen
> Cc: mapserver-users at lists.osgeo.org
> Emne: Re: SV: [mapserver-users] Mapserver consuming Google Maps
> Niels-Peter,
> I really do not see the need for this.
> All things, which are fun regarding Mapserver are not possible with
> GoogleMaps, e.g. reprojection or define your map layout in an easy way.
> Even if you would write some piece of code, which would enable mapserver
> getting that google tiles as a datasource you'll have at least a slower
> service than pure google and - if reprojecting the google stuff - you'll
> have "unreadable" maps with distorted labels.
> So beside the fact Chris already mentioned - I think if you have a
> client, which is able to show Mapserver services AND google map services
> together, you're fine, or what is your intention?
> Regards, Till
>> Yes, it could be a violation of terms, but not if the copyright notice
>> and links still is there - or am I wrong on that ? At least, thats
>> this is what the Openlayers community thinks. I think it would be a
>> very nice if that could be accomplished with MapServer too.
>> Niels-Peter
>> Fra: Christopher Schmidt [mailto:crschmidt at metacarta.com]
>> Sendt: 25. august 2009 17:14
>> Emne: Re: [mapserver-users] Mapserver consuming Google Maps
>> On Tue, Aug 25, 2009 at 04:42:27PM +0200, Niels-Peter Jensen wrote:
>>> Hi mapserver users
>>> Does anybody know if there has been done work to let MapServer
>>> consume
>>> Google maps ? I know that this is possible in OpenLayers (an example:
>>> http://openlayers.org/dev/examples/google.html), but with MapServer I can
>>> only se it the other way around, MapeServer serving maps til a GoogleMaps
>>> application by WMS.
>> Doing so would be a violation of the terms of use of Google Maps.
>> Regards,
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
