[mapserver-users] Repeated map tiles using Open Layers
The Chimpster
js at c-a.co.uk
Thu Aug 27 06:17:18 EDT 2009
Making use of Open Layers 2.8 with Map Server For Windows 2.3.1 which
contains MapServer 5.2.1
I'm using locally available Ordnance Survey map tiles (will be used on an
intranet, so no internet sources)
When querying mapserv.exe directly, the map is rendered fine, however when
viewing the map through Open Layers, the image appears repeated (image
attached)
http://n2.nabble.com/file/n3523736/MapWoe.png
I'm assuming it's maybe a projection issue, but have tried specifying the
projection both when initialising the OpenLayers.Map, the OpenLayers.Layer,
in the .map file and each of the .map files for the different zoom levels,
and various combinations of these, all to no avail.
The projection should be EPSG:27700.
Any suggestions or input would be welcome
View this message in context: http://n2.nabble.com/Repeated-map-tiles-using-Open-Layers-tp3523736p3523736.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
