[mapserver-users] MapServer 5.2.1 performance
Andy Colson
andy at squeakycode.net
Thu Aug 27 10:07:25 EDT 2009
Gorka Lopez wrote:
> Hi,
> I have a .map file with 120 layers. All this layers contain different
> information and this project is prepared to consume all these layers
> together. The style of those layers is basic (some annotations and some
> tematics)
> This layers consumes PostGIS tables (28 tables) which disk spaces are
> between 1 MB and 1GB (database total space: 2,5GB). The indexes of these
> tables (gist and btrees indexes) and the statistics are created. These
> information are in the same coordinate system that in the requested tiles.
> I want to improve the performance and I have the following results for a
> 512x512 tile:
> * 27 milliseconds per visible layer (layers that are visible in the map's
> scale (40 layers))
> * 18 millisecods per non-visible layer (layers that are not visible in the
> map' scale (80 layers))
> Is there any solution to improve this results (I just use tilechache
> metatile property)? I think that 18 milliseconds per non-visible layer is
> too much (only for evaluating wether the requested tile is contained in the
> layer's min/max scale)
> Thanks for your help.
> Best regards,
> Gorka López
Did you use the mapfile debug to get the timings? Did you profile any
of the sql statements? (In PG do you log slow sql statements? Or log
them all and use 'explain analyze' on them to make sure they are all
running fast?)
Are the program and database on the same box? (ie is there network
latency problems?)
Are you using mapserv as cgi? OpenLayers? something else?
-Andy
