[mapserver-users] Mapserver WMS under IIS 7 x64 serving up blank
images
Daniel Morissette
dmorissette at mapgears.com
Mon Dec 7 15:38:01 EST 2009
Daniel Walton wrote:
> Yes, the same mapfile worked under MS4W on a 32-bit machine. I have
> verified that this same problem occurs using the x86 binaries from
> Tamas' site run in the current x64 environment. The source image is in
> PNG format in order to make transparency work well on the client. (My
> client is Silverlight-based, and PNG is the only supported format that
> supports transparency). The source image does have a world (*.WLD) file
> which contains these values (file is generated by running gdal_translate
> on a geotiff image):
Um... perhaps try using DEBUG/MS_ERRORFILE and look for hints in the log
output, if you haven't tried that already.
Daniel Morissette
http://www.mapgears.com/
