[mapserver-users] mapserver 5.6.0, RFC 52 and driver support
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Wed Dec 23 10:59:59 EST 2009
Quite close. Output format should be (5.6 doesn't require the quotes around TEMPLATE in the driver line):
OUTPUTFORMAT
NAME 'UnassignedWells_select_template'
DRIVER 'TEMPLATE'
MIMETYPE 'text/html'
FORMATOPTION 'FILE=database\UnassignedWells_select_template_test.html'
END
Your URL looks fine.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Brent Fraser
Sent: Tuesday, December 22, 2009 4:30 PM
To: Lime, Steve D (DNR)
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] mapserver 5.6.0, RFC 52 and driver support
I've got:
OUTPUTFORMAT
DRIVER 'TEMPLATE'
TEMPLATE 'database\UnassignedWells_select_template_test.html'
#? FORMATOPTION 'FILE=database\UnassignedWells_select_template_test.html'
END
in my map file and a command line of:
mapserv
QUERY_STRING="mode=nquery&qformat=UnassignedWells_select_template&map=select2_Test.map&qlayer=UnAssignedWells&"
Am I close?
Thanks
Brent
> Yup. What sort of an example would help?
> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
> Sent: Tuesday, December 22, 2009 4:18 PM
> I'd like to give the new-style approach a try, but the doc seems a little
> thin. You've talking about RFC 36 right?
>> The new-style approach opens the template only once. That's not your
>> bottleneck though I bet...
>> Sent: Tuesday, December 22, 2009 3:34 PM
>> support
>>> What kind of templating are you using? The old-style stuff or the
>>> new-style? How many results you talking?
>> Old style. Low 100's of records returned...
>>> Sent: Tuesday, December 22, 2009 3:10 PM
>>> support
>>> The strange thing is the image render is quick (a few seconds), but the
>>> nquery+mapshape (rectangle) with the processing of the template is
>>> several
>>> minutes. And while it opens/reads/closes the template file for each
>>> record(!), I suspect the majority of the time is spent requesting the
>>> record and dealing with the result.
>>> Ok, on goes the hacker suit...
>>> Thanks!
>>> Brent
>>>> Probably a question better answered by OGR maintainers... In theory
>>>> working off a single
>>>> result set, even if you have to traverse it more than once, would be
>>>> far
>>>> more efficient
>>>> than id-based lookups done now.
>>>> Steve
>>>> Fraser
>>>> Sent: Tuesday, December 22, 2009 2:55 PM
>>>> support
>>>> Do you think there would be any point in making the changes for OGR
>>>> (for
>>>> my ODBC -> Sql Server connection)? If so, I'll start having a look at
>>>> the
>>>> code...
>>>> Brent
>>>>> The improvements are limited to native drivers only, principally
>>>>> Oracle
>>>>> Spatial and PostGIS.
>>>>> Steve
>>>>> Fraser
>>>>> Sent: Tuesday, December 22, 2009 2:48 PM
>>>>> To: mapserver-users at lists.osgeo.org
>>>>> Subject: [mapserver-users] mapserver 5.6.0, RFC 52 and driver support
>>>>> To all,
>>>>> I've got a query performance problem I'm trying to track down. I
>>>>> was
>>>>> hopeful that 5.6 with RFC 52 implemented might help me, but it seems
>>>>> to
>>>>> have no impact.
>>>>> Are the changes for RFC 52 implemented for OGR ODBC connections?
>>>>> Thanks!
>>>>> Brent Fraser
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
