[mapserver-users] problem with raster data..
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Feb 1 23:26:45 EST 2009
MeLv1n wAuRaN wrote:
> i already included the gdaltindex path in the environment variable.
> But another error occured, it said:
> "C:\ms4w\data\raster>gdaltindex sample_index.shp sample*.tif
> ERROR 4: Unable to open sample_index.shp or sample_index.SHP.
> Creating new index file...
This error is ok, it is just telling you that the index file does not
already exist and it is creating a new one. gdaltindex appends to an
existing file so keep that in mind if you need to add to your tileindex.
> ERROR 4: `sample*.tif' does not exist in the file system,
> and is not recognised as a supported dataset name.
This says that there are no files in the current directory named
sample*.tif what does a dir command respond with?
-Steve W
> Unable to open sample*.tif, skipping."
> what do you think is the problem here?
> --- On *Sat, 1/31/09, Robert Sanson /<SansonR at asurequality.com>/* wrote:
> From: Robert Sanson <SansonR at asurequality.com>
> Subject: Re: [mapserver-users] problem with raster data..
> To: death_knight0911 at yahoo.com
> Date: Saturday, January 31, 2009, 12:27 PM
> It looks like it can't find gdaltindex.exe in the PATH environment
> variable. You will have to add the directory that gdaltindex.erxe
> lives in to your PATH variable, via Control Panel.
> Option 2 is to specify the location of gdaltindex.exe when you run it:
> eg.
> C:\ms4w\data\raster>C:\ms4w\tools\gdaltindex sample_index.shp
> sample*.tif
> Robert
> >>> MeLv1n wAuRaN <death_knight0911 at yahoo.com> 30/01/2009 4:36 p.m. >>>
> hi again robert,
> i tried running it in the cmd but it gives me an error message:
> 'gdaltindex' is not recognized as an internal or external command,
> operable program or batch file.
> so, what did i miss in the mapserver configuration? i'm using MS4W_2.3.1
> --- On *Fri, 1/30/09, Robert Sanson /<SansonR at asurequality.com>/* wrote:
> Date: Friday, January 30, 2009, 11:11 AM
> If you intend to store the sample_index.shp file in the same
> directory as your TIF files, then open a DOS cmd window and
> navigate to that directory "cd c:\ms4w\data\raster". once you
> are there, simply run:
> This will create the sample_index.shp file in that directory.
> the accompanying .dbf file will haev a single attribute field
> "Location" that will hold the name of each TIF file.
> If you want, you can spatially index this file using the shptree
> utility that comes with Mapserver. It will create a spatial
> index .qix file.
> In your Map file you will need to specify the location of the
> sample_index.
> regards,
> Robert
> Click here <https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==>
> to report this email as spam.
> The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
> This message has been scanned for malware by SurfControl plc.
> www.surfcontrol.com <http://www.surfcontrol.com/>
> mapserver-users at lists.osgeo.org
