[mapserver-users] segmentation fault with endless recursion
Martin Kofahl
M.Kofahl at gmx.net
Wed Feb 4 02:27:34 EST 2009
Try to add a STYLE section (even empty - STYLE END) in you class
CLASS
EXPRESSION ""
NAME "Pont"
END
Martin
-------- Original-Nachricht --------
> Datum: Tue, 3 Feb 2009 14:44:26 +0100
> Von: "Balázs Bámer"
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] segmentation fault with endless recursion
> Hi All,
> I always receive segmentation fault for the map file here:
> http://www.bamer.hu/proba.map
> My GDAL version can see in part of gdb backtrace:
> #9426 0xb7983d5b in sincos () from /usr/lib/libgdal1.5.0.so.1
> #9427 0xb7983d5b in sincos () from /usr/lib/libgdal1.5.0.so.1
> #9428 0xb7983d5b in sincos () from /usr/lib/libgdal1.5.0.so.1
> The OS is Ubuntu Linux 8.10 I installed gdal using apt-get. Installed
> packages are
> gdal-bin install
> libgdal-doc install
> libgdal1-1.5.0 install
> libgdal1-dev install
> actual libgdal is /usr/lib/libgdal1.5.0.so.1.12.2
> My Mapserver is configured with the line below:
> ./configure --with-oci
> --with-oraclespatial=/usr/local/instantclient_11_1 --with-proj
> --with-threads --with-gdal --with-ogr --with-jpeg --with-png=/usr/lib
> --with-php=/usr/include/php5
> configure output here:
> http://www.bamer.hu/konf
> What is the problem with gdal?
> Thank you in advance.
> Best regards: Balázs Bámer
