Antwort: [mapserver-users] msOracleSpatialLayerGetShape():
OracleSpatial error. Error: ORA-00932
umn-ms at hydrotec.de
Wed Feb 4 09:24:50 EST 2009
Hi
I think you shouldn't query 2 geometry-columns at once
Either
DATA "GEOMETRIA FROM (SELECT ID, GEOMETRIA FROM GEOM) USING UNIQUE ID SRID
XYZ"
or
DATA "GEO_CENTROID FROM (SELECT ID, GEO_CENTROID FROM GEOM) USING UNIQUE
ID SRID XYZ"
If you want to have the Centerpoint in Getfeatureinfo you may try:
DATA "GEOMETRIA FROM (SELECT ID, GEOMETRIA, GEO_CENTROID.SDO_POINT.X,
GEO_CENTROID.SDO_POINT.Y FROM GEOM) USING UNIQUE ID SRID XYZ"
Bye
Benedikt Rothe
mapserver-users-bounces at lists.osgeo.org schrieb am 04.02.2009 14:58:02:
> Hi,
> I've created a simple Oracle table, which contains NUMERIC id,
SDO_GEOMETRY
> shape and SDO_GEOM.SDO_CENTROID based on shape. There are spatial
indexes on
> both geometry columns.
> GetMap requests are valid and I can see the map. However, when
requesting a
> GetFeatureInfo I receive:
> Layer 'SHAPE'
> Content-type: application/vnd.ogc.se_xml
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.0/exception_1_1_0.dtd">
> <ServiceExceptionReport version="1.1.0">
> <ServiceException>
> msOracleSpatialLayerGetShape(): OracleSpatial error. Error: ORA-00932:
> inconsistent datatypes: expected %s got %s
> . Query statement: SELECT ID, GEO_CENTROID, GEOMETRIA FROM GEOM WHERE
ID =
> 18746 .Check your data statement.
> </ServiceException>
> </ServiceExceptionReport>
> below my WMS request:
> http://localhost/cgi-bin/mapserv?map=/map/shape.
> map&service=WMS&VERSION=1.1&SRS=EPSG:
> 4326&LAYERS=SHAPE&TRANSPARENT=true&FORMAT=image%
> 2Fpng&REQUEST=GetFeatureInfo&STYLES=&EXCEPTIONS=application%2Fvnd.
> ogc.se_xml&BBOX=17.545968%2C51.146653%2C17.552216%2C51.
151939&X=374&Y=146&INFO_FORMAT=mime&QUERY_LAYERS=SHAPE&WIDTH=656&HEIGHT=555
> any help apriciated!
> View this message in context: http://n2.nabble.
> com/msOracleSpatialLayerGetShape%28%29%3A-OracleSpatial-error.-
> Error%3A-ORA-00932-tp2268870p2268870.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090204/9bdf6368/attachment.html
