[mapserver-users] c# or php?
Pietro Giannini
pgiannini at bytewise.it
Fri Feb 6 12:43:30 EST 2009
Hi Michele,
I'm currently working on a C# MapScript application on a SharePoint
environment.
I cannot answer your 1st question, but if you already developed a test app
you shouldn't have problems...
I currently use the csharp_mapscript that came with the last ms4w, no
matter to recompile it.
Maybe the idea of use both apache-php and iis-.net is possible, but it
seems me an unnecessary complication.
I found usefully this article - for PostGIS connection too:
http://www.paolocorti.net/2006/09/20/mapserver-tutorial-for-c-mapscript-asp-net/
ciao ................ pg
Pietro Giannini
Bytewise srl - Area GIS
41°50'38.58"N 12°29'13.39"E
On Ven, Febbraio 6, 2009 17:13, Shimomura, Michele L.- Environmental
Health wrote:
> Hi all,
> I'm pretty new to MapServer and I've created some proof of concept apps,
> but I'm at a decision point for how to move forward and would like to
> hear others' opinions.
> First, the small applications that I created were in Visual Studio 2008
> using the c# mapscript that came with the MS4W package, but now I've
> found out that our Windows 2003 server is running IIS 6 in 64-bit mode.
> So, my question is:
> 1) Can I compile everything to work in Windows and 64 bit and are there
> instructions on how to do that somewhere? In googling, I read something
> about buildbot, but that site seems to be down.
> 2) Or, would I be better off just using Apache and the PHP
> mapscript?
> I'll be integrating these maps into a SharePoint Intranet environment
> (built in c#), so that's why my preference is towards that way. And if
> I go with #2, I'm thinking I can still use my c# front end but then
> create php web services to return functionality. Also, eventually, the
> functionality will need to be able to insert/update PostGreSQL spatial
> data.
> I would love to hear from others who have done this before because, if
> possible, I'd like to avoid getting way down path only to have many
> unexpected surprises.
> Thanks in advance for your help!
> Michele
> mapserver-users at lists.osgeo.org
