[mapserver-users] gmap-ms46 demo map not rendering properly
kmanoj-pg7 kmanoj-pg7
kmanoj-pg7 at iiitmk.ac.in
Fri Feb 13 06:32:26 EST 2009
hello users...
I am a newbie to mapserver. i am trying to get the gamp demo to run in my
machine fedora 9. i have installed mapserver 5.0.3-3 and php-mapserver
5.0.3-3 extension for php/mapscripting. Moreover i installed all the
libraries and packges whatever mentioned in the installation documentation
perfectly.
i have added the AddTypes in the httpd.cong. Perhaps i have made the edits
in the php.ini file. now when i call the
http://localhost/gmap/gmap75.phtml
i stunned to see everything is projecting except the map is not rendering.
at the beginning i thought it might be a problem of the java mode is enabled
then i tried to disabled that but i failed it was also not working means the
button was not working.... Then i looked into the httpd error log file ...
i got this following error............
[Wed Feb 11 15:06:53 2009] [error] [client 127.0.0.1] PHP Notice: Undefined
variable: HTTP_POST_VARS in /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on
line 40, referer:
[Wed Feb 11 15:06:54 2009] [error] [client 127.0.0.1] PHP Notice: Undefined
variable: HTTP_GET_VARS in /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on
line 42, referer:
[Wed Feb 11 15:06:54 2009] [error] [client 127.0.0.1] PHP Notice: Use of
undefined constant MS_GIF - assumed 'MS_GIF' in
/var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line 53, referer://
/var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line 54, referer:
[Wed Feb 11 15:06:57 2009] [error] [client 127.0.0.1] PHP Notice: Undefined
index: MAP_NAME in /var/www/html/gmap-ms46/htdocs/gmap75.phtml on line 589,
referer://
[Wed Feb 11 15:07:16 2009] [error] [client 127.0.0.1] File does not exist:
/var/www/html/gmap-ms46/htdocs/netscape
Then i opened my gmap75.phtml file i did some modification means i changed
the value of $gblsHtmlMode to 1 actually its value is 0.. as you can see
from the following snippet...
if (strlen($HTTP_FORM_VARS["PREVIOUS_MODE"])==0)
$gbIsHtmlMode = 1; // Start with Java On by default
else
$gbIsHtmlMode = intval($HTTP_FORM_VARS["PREVIOUS_MODE"]);
wow its great...... i was surprised this time , the map rendered .... but
unfortunately all my happiness was just for a few minutes... when i was try
to zoom the map.... i failed it doesnt work... again i checked my httpd
error log file ... i got the following error...
[Thu Feb 12 14:16:10 2009] [error] [client 127.0.0.1] PHP Notice: Undefined
line 40
line 42
[Thu Feb 12 14:16:10 2009] [error] [client 127.0.0.1] PHP Notice: Use of
index: MAP_NAME in /var/www/html/gmap-ms46/htdocs/gmap75.phtml on line 63
index: minx in /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line 167
index: MapSize in /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line 187
index: KEYMAP_x in /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line
205
index: ViewRegion in /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line
274...
actually am getting few more errors like above but i have mentioned very
little.... these errors are similar to the above first errors....
i am struggling to solve this problem for the past two days...... someone
please help me out.....
any help/tips will be appreciated....
Thanks,
kapilmanoj
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090213/1fa2a613/attachment-0001.html
