[mapserver-users] gmap-ms46 demo map not rendering properly
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Feb 13 07:43:21 EST 2009
kmanoj-pg7 kmanoj-pg7 wrote:
> hello users...
> I am a newbie to mapserver. i am trying to get the gamp demo to run in my
> machine fedora 9. i have installed mapserver 5.0.3-3 and php-mapserver
> 5.0.3-3 extension for php/mapscripting. Moreover i installed all the
> libraries and packges whatever mentioned in the installation documentation
> perfectly.
> i have added the AddTypes in the httpd.cong. Perhaps i have made the edits
> in the php.ini file. now when i call the
> http://localhost/gmap/gmap75.phtml
> i stunned to see everything is projecting except the map is not rendering.
> at the beginning i thought it might be a problem of the java mode is enabled
> then i tried to disabled that but i failed it was also not working means the
> button was not working.... Then i looked into the httpd error log file ...
> i got this following error............
> [Wed Feb 11 15:06:53 2009] [error] [client 127.0.0.1] PHP Notice: Undefined
> variable: HTTP_POST_VARS in /var/www/html/gmap-ms46/
> htdocs/gmap75.inc.php on
> line 40, referer:
> [Wed Feb 11 15:06:54 2009] [error] [client 127.0.0.1] PHP Notice: Undefined
> variable: HTTP_GET_VARS in /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on
> line 42, referer:
> [Wed Feb 11 15:06:54 2009] [error] [client 127.0.0.1] PHP Notice: Use of
> undefined constant MS_GIF - assumed 'MS_GIF' in
> /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line 53, referer://
> /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line 54, referer:
> [Wed Feb 11 15:06:57 2009] [error] [client 127.0.0.1] PHP Notice: Undefined
> index: MAP_NAME in /var/www/html/gmap-ms46/htdocs/gmap75.phtml on line 589,
> referer://
> [Wed Feb 11 15:07:16 2009] [error] [client 127.0.0.1] File does not exist:
> /var/www/html/gmap-ms46/htdocs/netscape
The GMap demo is very old and requires you to change your php.ini
settings for error reporting to not show notices:
error_reporting = E_ALL & ~E_NOTICE
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
