[mapserver-users] Selective Background Transparency with
Labels
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Fri Feb 13 10:34:48 EST 2009
Bill,
Upon reflection, I guess you could build the background and contours as a single image, so you would only really need to build two images.
bobb
>>> thomas bonfort <thomas.bonfort at gmail.com> 02/13/09 9:19 AM >>>
On Fri, Feb 13, 2009 at 16:16, Bob Basques <Bob.Basques at ci.stpaul.mn.us> wrote:
> Bill,
> I understand (I think what you're after. The only way I can figure out how to do this would be with three images stacked on top of each other.
> You would generate the background first,
> then build the contour lines separately,
> lastly, the labels, which would be drawn with the contours again but the contours would be drawn over the labels with the same color as the background (transparent color).
> Stacking these all together I think will get you the desired effect.
> You would need something like GeoMoose or openlayers to view the stack though.
> bobb
>>>> thomas bonfort <thomas.bonfort at gmail.com> 02/13/09 8:37 AM >>>
> If I correctly understand what you're trying to do, then no, this is
> not possible with mapserver, as this would require recovering the
> pixels that have been overdrawn by the line.
> regards,
> thomas
> On Fri, Feb 13, 2009 at 15:14, Bill Thoen <bthoen at gisnet.com> wrote:
>> Is there a way to set a LABEL BACKGROUNDCOLOR to render transparent just
>> pixels of a particular color instead of changing all pixels to the specified
>> color? My situation is regarding contour line labels. I want the label to
>> follow the contour line's center, but I would like just the parts of the
>> contour line behind the labels to be knocked out, leaving the background
>> otherwise untouched. In this case the color of the layer just below the
>> contour lines varies across the map (it's a shaded relief layer), so setting
>> BACKGOUNDCOLOR to a specific value doesn't give me the effect I want. Any
>> solutions?
>> - Bill Thoen
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
