[mapserver-users] Layer must have an EPSG or AUTO projection code
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Feb 26 05:24:42 EST 2009
Just for clarification, are you trying to connect to some external WMS service and cascade it through Mapserver?
And the WMS layers that fail look something like this:
LAYER
NAME "prov_bound"
TYPE RASTER
STATUS ON
CONNECTION "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:42304"
"wms_name" "prov_bound"
"wms_server_version" "1.1.1"
"wms_format" "image/gif"
END
END
What do you actually mean with "I have exported from QGIS. All layers are shape files."?
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta asle
> Lähetetty: 26. helmikuuta 2009 12:15
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Layer must have an EPSG or AUTO
> projection code
> Hello,
> Trying to get mapserver to work on Mac OS X Server 10.5.6.
> Here is my setup:
> MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=GEOS
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I get this error when accessing the map file:
> msBuildWMSLayerURL(): WMS connection error. Layer must have
> an EPSG or AUTO projection code (in its PROJECTION object or
> wms_srs metadata) (If I try to remove all WMS layer I can see the map)
> I have exported from QGIS. All layers are shape files. I
> checked that all layers have the same EPSG id (32632) and all
> have same projection code. I tried several exports checking
> this but still get this error.
> /asle
> http://n2.nabble.com/Layer-must-have-an-EPSG-or-AUTO-projectio
> n-code-tp2388793p2388793.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
