[mapserver-users] WFS Layer + C# map script
Murty Maganti
MMaganti at oriongis.com
Thu Feb 26 13:59:35 EST 2009
Hi Assefa
Yes, the problem seems to be related to the GML file not accessible. I
normally leave WEB->IMAGEPATH empty in my map files as my application
displays map image on a windows form directly. When I started adding
support for WMS layers, I noticed that it is using imagepath to store
temporary files. I didn't want to specify a qualified path as the map
file will not load on other machines which may not have the same path. I
tried "\" (after briefly scanning through msBuildPath and msBuildPath3
methods) and it worked for WMS. I guess "\" gets resolved to location of
the map file.
But same is not working for WFS. If I change the path from "\" to a
fully qualified path, I don't see that error any more. But I don't want
to use fully qualified path. I want to use any relative path that can be
resolved to map file path or shappath or any other location. What is the
best relative path I can use for imagepath that can work for WMS/WFS or
any other data sources that use this to store temporary files.
Thanks
Murty
-----Original Message-----
From: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca]
Sent: Thursday, February 26, 2009 11:13 AM
To: Murty Maganti
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] WFS Layer + C# map script
Hi Murty,
MapServer does a request to the WFS server to get the GML file. This
GML file is saved locally and rendered by OGR as a vector layer.
You might want to check the file you got from the server (should be
inside web.imagepath (xxxx.tmp.gml) and see if it is valid or/if can be
opened with ogr.
Best Regards
Murty Maganti wrote:
> Hi
> I am trying load a WFS layer and getting the following error calling
> mapObj.draw(). Is WFS layer handled by OGR or is it handled directly
by
> map server. When I ran 'orginfo -formats', it does not show WFS as
> supported format by OGR. WFS URL in map file is correct and I can see
> the capabilities xml in browser using the url.
> Here is the error
> msDrawMap(): Image handling error. Failed to draw layer named
> 'Municipality (id=0)'.;msOGRFileOpen(): OGR error. Open failed for OGR
> connection in layer ` Municipality (id=0)'. File not found or
> unsupported format.
> Layer entry in the map file
> LAYER
> CONNECTION "http://vmonp03/wfsconnector/com.esri.wfs.Esrimap/
MS01?"
> CONNECTIONTYPE WFS
> METADATA
> "wfs_srs" "EPSG:26917"
> "wfs_request_method" "GET"
> "wfs_typename" "Municipality-0"
> "wfs_service" "WFS"
> "wfs_version" "1.0.0"
> END
> NAME "Municipality (id=0)"
> STATUS ON
> TYPE POLYGON
> UNITS METERS
> CLASS
> STYLE
> COLOR 184 155 225
> OPACITY 100
> OUTLINECOLOR 0 0 0
> SYMBOL 0
> END
> END
> END
> Thanks
> Murty
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
