[mapserver-users] WMS problem
Andrea Ardito
andrea.ardito at provincia.biella.it
Fri Feb 27 06:48:59 EST 2009
Hi Pietro,
1.I've tried to invoke mapserver in cgi mode and it seems ok.
http://webgis.provincia.biella.it/cgi-bin/mapserv?map=/opt/fgs/apps/mapservergeo/map/basewms.map&mode=map&layer=stati
2. We looked on the apache log file and we fixed some errors we had in a php
file.
Anyway things are not changed.
http://webgis.provincia.biella.it/apps/maplab/projects/gmf_apps/basewms4/wmdmap.php
Please, do you have anything else to suggest?
Thank you very much for your help
ciao
andrea
arch. Andrea ARDITO
Sistema Informativo Territoriale Ambientale (S.I.T.A.)
Settore Pianificazione e Sicurezza del Territorio
Provincia di Biella
Via Quintino Sella, 12 - 13900 BIELLA
tel. 015.8480880
fax. 015.8480740
-----Original Message-----
To: mapserver-users <mapserver-users at lists.osgeo.org>
Date: Thu, 26 Feb 2009 16:11:41 +0100
Subject: Re: [mapserver-users] WMS problem
Hi Andrea,
1. no
2. no matters
3. It is difficult to answer...
If the problem is EXTENT & PROJECTION, remember that a .map file
has the PROJECTION set at map level and PROJECTIONs set at layers
level; the map Projection is the projection system of the result of the
map (i.e. the map image), the layer Projection is the projection system
of the data source of the layer. If a layer datasource projection
differs from the map projection, you must to set it, otherwise ms try
to project the data according with map projection.
Try invoke mapserver in cgi mode to see the results:
http://the.host/cgi-bin/mapserv?map=/path/of/the.map&mode=map&layer=
[http://the.host/cgi-bin/mapserv?map=/path/of/the.map&mode=map&layer=]...
Imho your problem isn't the map, but occurs in your php script. Take a
look on the php error log: it is a text file, its path is set in your
php.ini file (error_log directive, can be an absolute or relative path)
4. obviously scale is nonsense when using non-projected reference
systems like epsg:4326, but mapserver does not know.
hth
ciao
....................pg
Pietro Giannini
Bytewise srl - Area GIS
41°50'38.58"N 12°29'13.39"E
Andrea Ardito ha scritto:
Hi, we have this system working with MapServer version 4.8.2, PHP
version 4.4.2. I am trying to do a map that shows both layer (WGS84
shapefile) and WMS data togheter. The starting response is ok, but I get the
blank image from the first pan or zoom on. This is the example URL:
[http://webgis.provincia.biella.it/apps/maplab/projects/gmf_apps/basewms4/wmdmap.php]
I guess the problem is due to wrong parameters for EXTENT, SIZE and
PROJECTION in the mapfile. These are: EXTENT -15 25 40 70 SIZE 470 520
PROJECTION "init=epsg:4326". The question are: 1. the SIZE (in pixel) has
to be proportional to the EXTENT? 2. if yes, how to obtain the right values
for the EXTENT? 3. if not, where is the problem? 4. in a map with geographic
non-projected data like this, is correct to have value for scale of the
representation since UNITS are DD? I would be very grateful for any help
from you all, thanks! Best regards andrea ardito P.S. If I set no layer in
the map file, and I try to represent only WMS layer (adding them from
"Servizi WMS" button), it works.
arch.
Andrea ARDITO
Sistema
Settore
Provincia
di Biella
Via
tel.
015.8480880
fax.
015.8480740
--http://www.provincia.biella.it------------------------------------------------------
Vuoi rimanere sempre aggiornato sulle nostre attivita'?
Visita la pagina dei feed RSS sul nostro sito ed iscriviti alla sezione
di interesse.
--Avviso------------------------------------------------------------------------------
Questo messaggio e i suoi allegati sono riservati esclusivamente alle
persone in
indirizzo e possono contenere informazioni confidenziali. Se questo
messaggio vi e'
pervenuto per errore, vi informiamo che ogni suo uso e'proibito.
In questo caso rispedite immediatamente il messaggio al mittente e
cancellatelo.
Per ogni chiarimento contattateci scrivendo a ced at provincia.biella.it
[mailto:ced at provincia.biella.it].
Grazie -Il Webmaster.
--Warning-----------------------------------------------------------------------------
This message and its attachments are addressed solely to the persons
above and may
contain confidential information. If you have received the message in
error, be
informed that any use of the content hereof is prohibited.
Please return it immediately to the sender and delete the message.
Should you have
any questions, please contact us by replying to
ced at provincia.biella.it [mailto:ced at provincia.biella.it].
The Webmaster.
mapserver-users mailing list
mapserver-users at lists.osgeo.org [mailto:mapserver-users at lists.osgeo.org]
http://lists.osgeo.org/mailman/listinfo/mapserver-users
[http://lists.osgeo.org/mailman/listinfo/mapserver-users]
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090227/475738a8/attachment-0001.html
