[mapserver-users] CGI mapserv.exe - BUFFER
Christopher Schmidt
crschmidt at metacarta.com
Thu Jan 8 14:24:26 EST 2009
On Thu, Jan 08, 2009 at 05:47:09PM -0000, Donald Kerr wrote:
> I'd appreciate it if someone could give me some clarification please?
> I am using the following url to return an image:
> http://localhost/cgi-bin/mapserv.exe?map=/ms4w/os.map&mode=map&mapsize=500+4
> 00&mapxy=258544+665909&layers=all&buffer=2000
> The documentation states, "BUFFER [distance] - A distance, in the same
> coordinate system as the map file, used in conjunction with MAPXY to create
> an new map extent".
> The coordinate system is in metres so I would expect that the width of the
> image (500px) would be 2000m (2km). That doesn't seem to be the case i.e.
> the returned images is, at a guess, double that.
"Buffer" is usually a 'radius' -- so, you've got 2000M on each side (4k
total, instead of the 2k you expect).
If you imagine picking the center piont, and drawing a $buffer_size
circle around it -- that's your extent.
Regards,
Christopher Schmidt
MetaCarta
