[mapserver-users] Imagemap size doesn't match display map
sscottgis
sorenscott at gmail.com
Mon Jan 12 14:17:01 EST 2009
David,
That did the trick. Thanks.
Fawcett, David wrote:
> Soren,
> I think that you are running into the issue where a WMS request can
> return non-square pixels, and that the ratio of height:width in your
> extent is not the same as the ratio of height:width in your image size.
> If you can make this as a regular CGI call, you won't see this problem.
> If you need to use WMS, make sure that you make the ratio's the same.
> e.g. 500/275 does not equal 60/26.
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of sscottgis
> Sent: Friday, January 09, 2009 12:48 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Imagemap size doesn't match display map
> I have created an imagemap/image for the lower 48 states using 2
> mapfiles to define the polygons following the demo in the wiki. They
> noted that if you use separate maps, the SIZE and EXTENT should be the
> same. I have those set the same in both files, but the imagemap that
> gets returned is vertically squished.
> Here's the map file for the imagemap layer:
> MAP
> NAME "droughtplan_imgmap"
> STATUS ON
> SIZE 500 275
> # set projection for map
> PROJECTION
> "init=epsg:4326"
> END
> EXTENT -126 24 -66 50
> UNITS METERS
> STATUS ON
> IMAGECOLOR 255 255 255
> WEB
> IMAGEPATH "e:/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> END
> #QUERYMAP
> # STATUS ON
> # STYLE NORMAL
> #END
> LAYER
> NAME "droughtplans_imgmap"
> STATUS DEFAULT
> TYPE POLYGON
> DATA "../data/droughtplans_imgmap"
> TEMPLATE "planbody.html"
> HEADER "planheader.html"
> FOOTER "planfooter.html"
> CLASSITEM "State"
> CLASS
> COLOR -1 -1 -1
> NAME "State"
> OUTLINECOLOR 110 110 110
> END
> END
> END
> END
> and the file for the display layer:
> MAP
> NAME "droughtplan_wms"
> STATUS ON
> SIZE 500 275
> PROJECTION
> "init=epsg:4326"
> END
> UNITS METERS
> STATUS ON
> # image format
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
> END
> WEB
> IMAGEURL "/ms_tmp/"
> HEADER "../templates/query_header.html"
> FOOTER "../templates/query_footer.html"
> END
> QUERYMAP
> STATUS ON
> STYLE NORMAL
> END
> LAYER
> NAME "droughtplans"
> STATUS DEFAULT
> TYPE POLYGON
> DATA "../data/droughtplans"
> DUMP TRUE
> HEADER ../templates/ndmc_query_header.html
> TEMPLATE ../templates/ndmc_query_body.html
> CLASSITEM "Status"
> CLASS
> COLOR 255 255 255
> EXPRESSION "0"
> NAME "No Plan"
> SYMBOL 0
> END
> CLASS
> COLOR 139 209 0
> EXPRESSION "1"
> NAME "Emphasizing Mitigation"
> SYMBOL 0
> END
> CLASS
> COLOR 255 255 0
> EXPRESSION "2"
> NAME "Emphasizing Response"
> SYMBOL 0
> END
> CLASS
> COLOR 255 128 0
> EXPRESSION "3"
> NAME "Emphasizing Disaster"
> SYMBOL 0
> END
> CLASS
> COLOR 255 0 0
> EXPRESSION "4"
> NAME "Local Plans"
> SYMBOL 0
> END
> END
> END
> END
> The header and footer are the basic <map> tags described in the wiki,
> but with the map height and width set to the 500, 275 dimensions from
> the files.
> Here's the body template:
> <area shape="poly" coords="[shpxy precision=0 proj=image]"
> href="http://myserver/Resources/state.aspx?state=[State]"
> title="[State]" alt="[State]">
> and the call to the image layer (these are part of an ASP.NET 2.0 web
> page and added as part of an httprequest):
> http://myserver/cgi-bin/mapserv.exe?map=/ms4w/apps/drmon/service/drought
> plans_wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=droughtpla
> ns&WIDTH=500&HEIGHT=275&srs=EPSG:4326&styles=default&format=image/png&bb
> ox=-126,24,-66,50
> I've got the extents and sizes set to the same 500, 275 dimensions
> everywhere, but the imagemap is still flattened (more like a box at 500
> x 200). Everything else works fine--all of the areas are defined, the
> links work,etc; it just isn't aligned properly. Is there something
> missing or something else going on here?
> Any help/ideas are greatly appreciated.
> Soren
> http://n2.nabble.com/Imagemap-size-doesn%27t-match-display-map-tp2134663
> p2134663.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
View this message in context: http://n2.nabble.com/Imagemap-size-doesn%27t-match-display-map-tp2134663p2147423.html
