[mapserver-users] GPX format supported?
Fawcett, David
David.Fawcett at state.mn.us
Tue Jan 13 16:59:44 EST 2009
Don't forget to set STATUS to DEFAULT, or explicitly request the layer
by name in the URL request.
David.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Tuesday, January 13, 2009 3:59 PM
To: bean at warbaby.com
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] GPX format supported?
bean at warbaby.com wrote:
> Hi Steve,
> Thanks for the rapid reply. I have removed the layers one by one. They
> all parse right but this GPX layer.
> Curiously if I remove the class statement (including the first end
> statement) I get no parse errors but the layer fails to render.
> Still puzzled,
> bean
>> Bean,
>> You probably have some other layer that does not have the block ...
>> ENDs match up correctly. Try making a mapfile with just the single
>> layer below and see if that works, then add another layer and test
it,
>> and so on until it breaks. Also check the all quoted strings are
>> properly terminated.
>> No magic here, just take it layer by layer until you find the
>> problem.
>> -Steve W
So the following nesting of tags looks correct:
LAYER
NAME 'GPS'
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
'/Applications/MAMP/d/DATA/NonGrassFiles/GPX/gpsbabel_output.gpx'
DATA 'waypoints'
STATUS ON
DEBUG 5
CLASS
STYLE
SYMBOL 'CIRCLE'
SIZE 3
OUTLINECOLOR 0 0 0
COLOR 106 7 182
END
END
END
I a can't help you a lot with the the OGR connection, as I don't use it
that often.
Are sure that DATA 'waypoints' is correct?
You might try at the command line, something like:
ogrinfo --formats
and verify that GPX is supported.
ogrinfo /Applications/MAMP/d/DATA/NonGrassFiles/GPX/gpsbabel_output.gpx
and see what it says. I would also ask OGR specific question on the
GDAL/OGR list, as they might have more info on ogr related problems.
-Steve
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
