[mapserver-users] RE: mapserver-users Digest, Vol 12, Issue 73
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Jan 20 09:34:06 EST 2009
Have you specified the projection also inside LAYER? There are two places for giving projections, in MAP section to give the set of available output projections, and in LAYER section to tell Mapserver which projection the layer data are in.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Chad Clabaugh
> Lähetetty: 20. tammikuuta 2009 16:29
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] RE: mapserver-users Digest, Vol 12, Issue 73
> Am I not specifying my projection by using "init=epsg:4326"
> within the PROJECTION BLOCK???? I have tried as many
> different projections as I can find. Including 4326, 900913,
> 3785, and the following block...
> PROJECTION
> "proj=merc"
> "a=6378137"
> "b=6378137"
> "lat_ts=0.0"
> "lon_0=0.0"
> "x_0=0.0"
> "y_0=0"
> "k=1.0"
> "units=m"
> "nadgrids=@null"
> "wktext"
> "no_defs"
> END
> ...which didn't work for me.
> Message: 3
> Date: Mon, 19 Jan 2009 20:16:28 -0800
> From: "Paul Ramsey" <pramsey at cleverelephant.ca>
> Subject: Re: [mapserver-users] google tiles
> To: "Chad Clabaugh" <cclabaugh at centwire.com>
> Cc: mapserver-users at lists.osgeo.org
> Message-ID:
> <30fe546d0901192016u1ad26e6fy7ec54e13da416c18 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> You need to specify the PROJECTION of your LAYER.
> P.
> On Mon, Jan 19, 2009 at 6:50 AM, Chad Clabaugh
> wrote:
> > Greetings,
> > I have been trying to generate google tiles from shapefiles using
> > mapserver. I have been able to successfully generate maps
> by calling
> > the url
> http://0.0.0.0/cgi-bin/mapserv?map=/srv/www/htdocs/mapserver/c
> overage.map&mo
> de=map
> > . but when I attempt to use the url
> http://172.18.154.186/cgi-bin/mapserv?map=/srv/www/htdocs/maps
> erver/coverage
> .map&mode=tile&tile=4+6+4
> > I receive only empty images, regardless of tile specified.
> > Thanks for any help!
> > MAP
> > NAME COVERAGE
> > STATUS ON
> > SIZE 1400 900
> > EXTENT 639000.000000 4535300.000000 689900.000000 4582600.000000
> > UNITS METERS
> > SHAPEPATH "shapefiles"
> > IMAGECOLOR 220 220 220
> > IMAGETYPE PNG
> > PROJECTION
> > "init=epsg:4326"
> > END
> > LAYER
> > NAME CoverageMap
> > TYPE POLYGON
> > STATUS DEFAULT
> > DATA notforchad
> > CLASS
> > STYLE
> > OUTLINECOLOR 255 128 128
> > COLOR 225 0 0
> > END
> > END
> > END
> > END
> > Chad Clabaugh
> > Technical Support, Engineering
> > Office: 260.760.6398
> > Mobile: 260.466.8861
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
