[mapserver-users] label FOLLOW and OFFSET
Tim Norris
tibben at OCF.Berkeley.EDU
Sat Jan 31 15:45:33 EST 2009
Hi all,
I have been playing with the FOLLOW label directive. What I am trying to
achieve is a label that follows the street that is also OFFSET so that
the label does not land on the line for the street, but instead 'above'
it. Below is the LABEL directives that I am using, but note that I have
also tried using the POSITION UC as well as the OFFSET 0 -6, but both
give the same results. Please see the attached JPG image, you can see
that 'M PARDO' is correct but that 'JR JUNIN' is not.
LABEL
COLOR 0 0 0
OUTLINECOLOR 255 255 255
TYPE TRUETYPE
FONT ArialBold
SIZE 7
ANTIALIAS TRUE
ANGLE FOLLOW
PARTIALS FALSE
MINFEATURESIZE 40
MINDISTANCE 50
OFFSET 0 -6
BUFFER 7
END
Any ideas as to why this is not working? I took a quick look in
maplabel.c, but could not see anything obvious . . .
thanks
tim
Tim Norris
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090131/98b45185/example-0001.jpg
