[mapserver-users] WMS + Layers with OPACITY
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Jun 2 10:04:45 EDT 2009
Satellite images tend to look ugly with 8 bits as you are serving now.
Try with 24-bit png by changing IMAGEMODE to RGB.
-Jukka Rahkonen-
Alvarez Saldarriaga wrote:
> Hey, I'm trying to use a WMS map from the NASA as myy BASE
> map and som other layers (SHP), but I don't know why the
> image looks so ugly, I'm using OpenLayers to render the map
> and mapserver on Ubuntu, I set the WMS as png and the other
> layers too, can somebody help me with this?, the map and the
> image are attached, Thx.
> This is the mapserver config:
> MapServer version 5.4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
> SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT =OGR INPUT=GDAL
> INPUT=SHAPEFILE
> My OpenLayers config:
> function showMap()
> objOpenLayers = new OpenLayers.Map( "show-map",
> { controls: [], /*
> zoom: 5 */ maxResolution: 'auto' } );
> objOpenLayers.addControl( new
> OpenLayers.Control.PanZoomBar() );
> OpenLayers.Control.MouseToolbar() );
> OpenLayers.Control.LayerSwitcher() );
> // objOpenLayers.addControl( new
> OpenLayers.Control.Permalink() );
> OpenLayers.Control.ScaleLine() );
> OpenLayers.Control.Permalink( 'permalink' ) );
> OpenLayers.Control.MousePosition() );
> OpenLayers.Control.OverviewMap() );
> OpenLayers.Control.KeyboardDefaults() );
> var twms = new OpenLayers.Layer.WMS( "NASA",
> "http://wms.jpl.nasa.gov/wms.cgi?",
> { map:
> '/home/jfalvarez/projects/cms/branches/V1/docroot/map-files/91
82340517c2d323061dc1cffea6e431.map',
> layers: 'BMNG',
> format: 'image/png'}, {isBaseLayer: true} );
> objOpenLayers.addLayer(twms);
> var objMapServer17 = new OpenLayers.Layer.MapServer(
> "Colombia Departamentos",
> "http://vesifront.org/cgi-bin/mapserv",
> map:
> "/home/jfalvarez/projects/cms/branches/V1/docroot/map-files/91
82340517c2d323061dc1cffea6e431.map",
> layers: "Colombia_Departamentos",
> // maxResolution: "auto",
> transparent: "true",
> format: "image/png"
> objOpenLayers.addLayer( objMapServer17 );
> var objMapServer18 =
> "Zona Bananera 2",
> map:
> layers: "Zona_Bananera_2",
> format: "image/png"
> objOpenLayers.addLayer( objMapServer18 );
> var objMapServer19 =
> "Zona Bananera 1",
> map:
> layers: "Zona_Bananera_1",
> format: "image/png"
> if ( !objOpenLayers.getCenter() )
> objOpenLayers.zoomToMaxExtent();
