[mapserver-users] Need help with ProxyPass configuration, please
Daniel Morissette
dmorissette at mapgears.com
Mon Jun 8 10:36:27 EDT 2009
cbrydon wrote:
> I have also tried the following (among other configurations), but just can't
> seem to get thiings to work....
> NameVirtualHost 111.111.111.111:80
> # Apache Site
> <VirtualHost 111.111.111.111:80>
> DocumentRoot "/ms4w/Apache/htdocs"
> ServerName 111.111.111.111
> </VirtualHost>
> # IIS Site
> ServerName 111.111.111.111:80
> DocumentRoot F:/Applications/2009/Custom/SomeTown
> ProxyRequests OFF
> ProxyPass / http://111.111.111.111:8080/
> ProxyPassReverse / http://111.111.111.111:8080/
> </VirtualHost>
> The above code doesn't work either; it seems as though the 2nd virtual host
> isn't being recognized. SomeTown is actually in F:/Applications/2009/Custom.
> Below is the output of an error log file.
Carl,
You need a single VirtualHost for what you're trying to do. You have to
decide which directories go to the proxy'd (IIS) server and list them
there, and then let the local (MS4W) server handle the rest.
For instance, if what you want is:
http://111.111.111.111/SomeTown -> IIS
http://111.111.111.111/AnotherTown -> IIS
http://111.111.111.111/ (anything else) -> MS4W
Then a config as follows should do the trick:
# Apache Site
# Forward some directories to the IIS server on port 8080
# Anything not explicitly proxy'd here is expected to be local by default.
ProxyPass /SomeTown http://111.111.111.111:8080/SomeTown
ProxyPassReverse /SomeTown http://111.111.111.111:8080/SomeTown
ProxyPass /AnotherTown http://111.111.111.111:8080/AnotherTown
ProxyPassReverse /AnotherTown http://111.111.111.111:8080/AnotherTown
</VirtualHost>
I hope that helps
Daniel
Daniel Morissette
http://www.mapgears.com/
