[mapserver-users] labeling streets
Thomas Bonfort
thomas.bonfort at camptocamp.com
Tue Jun 9 02:18:11 EDT 2009
Raivo,
are you sure that your streets only contain one feature?
If you are using 5.4+, you can check by appending a geomtransform
style to your street layer, to draw a symbol at the beginning of each
feature:
style
geomtransform "start"
symbol "circle"
color 255 0 0
size 15
end
regards,
thomas
www.camptocamp.com
+33 4 79 26 57 97
On Tue, Jun 9, 2009 at 07:50, Raivo Alla<snaperski at gmail.com> wrote:
> Thank You,
> so it should be, but somehow in my case it does not work properly.
> When i have no declaration of MINFEATURESIZE, then the picture looks fine:
> http://picasaweb.google.com/snaperski/Ort#5345194219497220482
> But when I add MINFEATURESIZE AUTO, most labels just disappear, even
> if they have enough space to fit in:
> http://picasaweb.google.com/snaperski/Ort#5345195269825705586
> And those labeled straight streets contain only one feature (line
> feature) each - so the label should fit in decently.
> Label is declared this way:
> LABEL
> TYPE truetype
> ANTIALIAS true
> FONT "arial"
> COLOR 240 240 240
> OUTLINECOLOR 52 52 52
> SIZE 9
> force false
> MINDISTANCE 250
> MINFEATURESIZE auto
> ANGLE follow
> POSITION cc
> BUFFER 1
> END
> Changing FORCE or POSITION parameters didnt help either....
> Raivo
> On Mon, Jun 8, 2009 at 12:55 PM, Christy Nieman<cnieman at dmsolutions.ca> wrote:
>> Hi,
>> You could set MINFEATURESIZE to AUTO and then only the labels that fit on
>> the lines should be drawn.
>> Regards,
>> Christy
>> Raivo Alla wrote:
>>> Hello!
>>> I'm stuck in simple-looking problem, but the solution is just hiding
>>> somewhere.
>>> The question is: how I can label only those line features, whos label
>>> does not run over the line like that:
>>> http://picasaweb.google.com/snaperski/Ort#5344831130138846050
>>> As street lengths are very different, I cant solve the problem by
>>> setting suitable MINFEATURESIZE for
>>> respective MINSCALE,MAXSCALE range.
>>> All the best,
>>> Raivo Alla
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
