[mapserver-users] cartographic lines
David Nugent
davidn at datalinktech.com.au
Tue Jun 9 02:21:32 EDT 2009
On Tue, 09 Jun 2009 14:06:09 +1000, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> Thomas Bonfort seems to do it this way:
> CLASS
> EXPRESSION "primary"
> STYLE
> WIDTH 14
> OUTLINECOLOR "#B7AC9A"
> OUTLINEWIDTH 1
> MINWIDTH 1.5
> MAXWIDTH 12
> END
> STYLE
> WIDTH 14
> COLOR "#FFFF7A"
> MINWIDTH 1.5
> MAXWIDTH 12
> END
> END
Thanks, I'll give it a shot and post the results. IIRC though when I tried
a variation of this a couple of weeks back I kept getting the mapserver
message: "Cartoline drawing is deprecated with AGG", so I figured that
wasn't the correct way to do it. :-)
And I had not realised that *COLOR directives accepted a hexadecimal value
as an alternative to R G B values! That will make things easier.
As to the other implied question in my OP - since I've discovered that
rendering with transparency on fixes a number of artifacts - so does
anyone know of a solution for setting background when rendering RGBA tiles
since IMAGECOLOR no longer seems to work?
> Note that since I am rendering a flat tile which includes a background
> I'm using RGB rather than RGBA and I suspect this may affect rendering of
> OPACITY in layers. However I can't seem to find the magic that will
> render a background colour other than black (and yes, I'm using
> IMAGECOLOR in the MAP section, but it seems to have no effect when
> rendering with
> transparency).
Regards,
David
