[mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI error
on IIS(5.1 and 6.0) ... Possible BUG?
Paul james
pauljame at gmail.com
Tue Jun 9 13:50:40 EDT 2009
Just one update in my tests...
Using FASTCGI It worked FINE (mapserver 5.4)...
I added a bug ticket : http://trac.osgeo.org/mapserver/ticket/3049
Paul
On Tue, Jun 2, 2009 at 10:12 AM, Paul james <pauljame at gmail.com> wrote:
> Probably is a mapserver CGI bug...
> Paul
> On Sat, May 30, 2009 at 11:56 PM, Brian Fischer <bfischer at houstoneng.com>wrote:
>> Paul,
>> Just to let you know you are not alone. I am experiencing the same
>> problem with MS4W 3.0 beta 1 and 2. I’ve reported it as a bug to the MS4W
>> project. Here’s a link to the bug report
>> http://bugzilla.maptools.org/show_bug.cgi?id=2043. I haven’t heard
>> anything back on a solution yet. I’m not sure if this is a MapServer bug or
>> a bug with the way the MS4W package was compiled. It runs fine of Apache
>> for me.
>> Brian Fischer
>> Houston Engineering, Inc.
>> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
>> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Paul james
>> *Sent:* Friday, May 29, 2009 1:08 PM
>> *To:* Steve Lime
>> *Cc:* mapserver-users at lists.osgeo.org; Daniel Morissette
>> *Subject:* Re: [mapserver-users] Re: Upgrading 5.2 -> 5.4 generating CGI
>> error on IIS(5.1 and 6.0) ... Possible BUG?
>> http://localhost/cgi-bin/mapserv.exe?map=C%3A%2Finetpub%2Fwwwroot%2FOpenlayer%2FFiles%2FMapserver%2FMap.map&mode=map&map_imagetype=png&mapext=-180+0+-90+90&imgext=-180+0+-90+90&map_size=256+256&imgx=128&imgy=128&imgxy=256+256
>> Paul
>> On Fri, May 29, 2009 at 3:01 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>
>> wrote:
>> What's the full URL submitted against the CGI?
>> >>> On 5/29/2009 at 12:59 PM, in message
>> <33fad6880905291059i5602a89q84d7673ddcfff511 at mail.gmail.com>, Paul
>> james
>> > 1 - I tried with 1500,1400,1310,development version(1500) and ms4w
>> beta...
>> > 2 - Ím using normal CGI
>> > 3 - My tests are only with Postgis... Íll generate a shapefile to
>> test
>> > later ...
>> > Paul
>> > On Fri, May 29, 2009 at 2:27 PM, Tamas Szekeres <szekerest at gmail.com>
>> wrote:
>> >> Hi Paul,
>> >> Did you experience the same with the release-1310 and release-1400
>> >> versions? Did you experience the same with the development version?
>> >> Are you using fastCGI or normal cgi?
>> >> Is this just a PostGIS related problem or you get the same with a
>> simple
>> >> shapefile?
>> >> Sorry for the bunch of the questions...
>> >> Best regards,
>> >> Tamas
>> >> 2009/5/29 Paul james <pauljame at gmail.com>
>> >>> Yes Daniel... I deleted all previous files and put only 5.4
>> files... My
>> >>> mapscript application is working fine on 5.4...
>> >>> But the CGI dont...
>> >>> Tested on Windows XP (IIS 5.1) and Windows 2003(IIS 6.0)...
>> >>> Paul
>> >>> On Fri, May 29, 2009 at 12:56 PM, Daniel Morissette <
>> >>> dmorissette at mapgears.com> wrote:
>> >>>> Paul james wrote:
>> >>>>> Hi Daniel...
>> >>>>> I got the binaries from Tamas build :
>> >>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>> >>>>> And from MS4W 3.0 beta2...
>> >>>>> Same result with both...
>> >>>>> That error you got is my fault... I took off the :
>> >>>>> IMAGE "..\Map.png"
>> >>>>> from REFERENCE definition when copy the code to email...
>> >>>>> My application works fine with 5.2 binary in iis 5.1 and 6.0
>> >>>>> Just replacing with 5.4 binary I got that 502 error...
>> >>>> Hopefully you always make sure you update all DLLs as well when
>> you
>> >>>> "replace with 5.4 binary"? Even if the DLLs have the same names,
>> if they
>> >>>> come from different build environments or versions they may not
>> be
>> >>>> compatible and could cause the kind of crashes that you are
>> experiencing.
>> >>>> Daniel
>> >>>> Daniel Morissette
>> >>>> http://www.mapgears.com/
>> >>> _______________________________________________
>> >>> mapserver-users mailing list
>> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090609/ad8d969e/attachment.html
