[mapserver-users] How to label a feature once.
Shawn Gervais
project10 at project10.net
Fri Jun 12 01:17:58 EDT 2009
Paul Moen wrote:
> I figured it out. The images I am using are tiled so there are 4 images
> server by Mapserver with each labeled one time, which gives the
> appearance of 4 labels on one feature. So, Mapserver is working exactly
> the way it should and I am not.
You can have MapServer use a fixed label point across tiles by using the
"PROCESSING 'LABEL_NO_CLIP=TRUE'" directive in your layer definition.
That should give you the result you expect.
-S
