[mapserver-users] Re: LABEL problem using CGI...
Ben Madin
ben at remoteinformation.com.au
Wed Jun 17 09:25:59 EDT 2009
Paul,
On 17/06/2009, at 8:31 PM, mapserver-users-request at lists.osgeo.org
wrote:
> You are right...
> It is Tiled (using OL)...
> In that case, How can I "fix" that effect?
> Thanks
use an Untiled or singleTile layer - ie if you are using it as a WMS,
then
var SouthAmerica = new OpenLayers.Layer.WMS(
'SouthAmerica',
'http://localhost/cgi-bin/mapserv?map=my.map&',
{transparent: 'true', layers: 'polys', isBaseLayer: 'false', version:
'1.1.1', srs: 'EPSG:4326'},
{singleTile: true}
and I think you can do the same for MapServer layers (but if you ask
on the openlayers list they will politely suggest that you use a WMS
layer!)
cheers
Ben
> On Tue, Jun 16, 2009 at 6:28 PM, Steve Lime <Steve.Lime at dnr.state.mn.us
> > wrote:
> And this is the result of a single call to the CGI with mode=map?
> MapServer doesn't just invent label placements like this and
> there should be no difference between a single image with mode=map
> or a
> single call to a mapObj's draw() method.
> Looks to me as if you sample image is the result of merging tiled
> images created from multiple calls to the CGI.
> Steve
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome WA 6725
Out here, it pays to know...
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090617/71de4382/attachment.html
