[mapserver-users] Contour maps
padma priya
vppriya at tenet.res.in
Sat Jun 20 01:07:36 EDT 2009
Thanks everyone for the replies. I will try out the suggestions and get back.
Cheers!
-----Original Message-----
Date: Fri, 19 Jun 2009 18:42:12 +0200 (CEST)
To: padma priya <vppriya at tenet.res.in>
CC: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Contour maps
Dear Padma,
You can use gdal_contour (found in gdal utilities) to generate contours
from a DEM, then mapserver can display contour vectors.
You can use several opensource software to generate DEM, e.g. GRASS, GTM
Best regards
Zoltan
On Fri, 19 Jun 2009, padma priya wrote:
> Hi All
> Can anyone tell me if it is possible to draw contour maps using mapserver.
> TIA
> Padma
