[mapserver-users] Precache
Guillaume Sueur
no-reply at neogeo-online.net
Sun Jun 21 10:59:08 EDT 2009
I'll be there too !
Best regards,
Guillaume
Varun saraf a écrit :
> It worked perfect.I have another question but I guess I will put it up
> on the tilecache-users list.
> Thanks a lot,
> Varun
> On Fri, Jun 19, 2009 at 6:55 PM, Guillaume
> Sueur<no-reply at neogeo-online.net> wrote:
>> Hi Varun,
>> It looks rather like a question for the tilecache-users list, but I can give
>> you a hand.
>> I think you didn't specify any layer when running tilecache_seed.py
>> Please try :
>> tilecache_seed.py [your_layer_name_as_set_in_tilecache.cfg] 0 5
>> where 0 and 5 are zoom start and zoom end. You can adapt this last one
>> depending on how many levels you set for your layer.
>> Run it from the directory where tilecache.cfg is, to avoid problem if you
>> have many of them...
>> Regards,
>> Guillaume
>>> Hello,
>>> I have got this (tilecache with mapserver on google maps) working
>>> finally after a lot of problems but I now really need to know about
>>> how to do a pre-cache of all the tiles from mapserver. I am running
>>> tilecache 2.10 on Windows with mapserver ms4w from maptools.org. I
>>> tried running "tilecache_seed.py" as per the suggestion above but it
>>> always ends up in the following error
>>> Traceback (most recent call last):
>>> File "C:\ms4w\Apache\cgi-bin\tilecache-2.10\tilecache_seed.py", line 9,
>>> in <mo
>>> dule>
>>> TileCache.Client.main()
>>> File "C:\ms4w\Apache\cgi-bin\tilecache-2.10\TileCache\Client.py", line
>>> 153, in
>>> main
>>> layer = svc.layers[args[0]]
>>> IndexError: list index out of range
>>> Any help in this regard would be great.
>>> Thanks,
>>> Varun
>>> On Fri, Jun 19, 2009 at 2:39 PM, Varun saraf<vsaraf.gmu at gmail.com> wrote:
>>>> Hi Roger,
>>>> I am trying to get my mapserver and tilecache work together but its
>>>> somehow not working. I am using the same projection as you in all my
>>>> layers and the mapfile. (This works when I call my mapserver directly
>>>> from google and hence the projection is right).
>>>> Here is my mapfile (Only things that might be important).
>>>> MAP
>>>> EXTENT -173 5 -45 75
>>>> IMAGETYPE PNG
>>>> PROJECTION
>>>> "init=epsg:4326"
>>>> END
>>>> WEB
>>>> METADATA
>>>> wms_srs "EPSG:4326 EPSG:900913"
>>>> END
>>>> END
>>>> LAYER
>>>> PROJECTION
>>>> "init=epsg:4326"
>>>> END
>>>> END
>>>> Next I added the 900913 epsg to the proj.4 of mapserver and made the
>>>> required changes in tilecache.cfg file as you specified.
>>>> [google-tiles]
>>>> type=MapServerLayer
>>>> mapfile=C:/ms4w/apps/QCTGIS/drawMap.map
>>>> metaTile=true
>>>> metaSize=2,2
>>>> metaBuffer=0,500
>>>> layers=tr20_d00
>>>> spherical_mercator=true
>>>> srs=EPSG:900913
>>>> I am not sure if the linkn I am using is wrong. I have tilecache
>>>> installed in the cgi directory of the apache server that was installed
>>>> using "ms4". The example index.html that comes with tilecache works
>>>> fine and I can see the images being cached. Also my mapserver directly
>>>> works fine. Can you tell me what is it that I am doing wrong here? the
>>>> link I use for the tileUrlTemplate in google maps is
>>>> "http://127.0.0.1:8123/cgi-bin/tilecache-2.10/tilecache.cgi/1.0.0/google-tiles/{Y}/{X}/{Z}.png?type=google".
>>>> I can also see that this call gets initiated in the apache logs
>>>> (access.log) but nothing happens therafter. I don't even know if this
>>>> is failing at tilecache end and mapserver isn't being called at all or
>>>> at mapserver's end where the image is not being sent by mapserver. Can
>>>> you help me out here?
>>>> Thanks a lot.
>>>> Varun
>>>> On Thu, May 21, 2009 at 12:46 PM, Roger André<randre at gmail.com> wrote:
>>>>> Ahh, ok. I'm not sure in what fashion you are using TileCache, but my
>>>>> experience has been with using it to create tiles to display in Google
>>>>> Maps. Google Maps uses the projection which is EPSG:900913. I
>>>>> believe there are other codes for it, but that is the one I use.
>>>>> All of my source data for the MapServer projects I make are in
>>>>> EPSG:4326. So there are 3 things I need to do in order to make the
>>>>> Tilecache output tiles align correctly in Gmaps.
>>>>> 1. I set both the mapfile and the layer projections to EPSG:4326.
>>>>> MAP
>>>>> NAME 'v2_80m_global'
>>>>> PROJECTION
>>>>> "init=epsg:4326"
>>>>> END
>>>>> LAYER
>>>>> NAME 'imagery'
>>>>> PROJECTION
>>>>> "init=epsg:4326"
>>>>> END
>>>>> <snip...>
>>>>> 2. I explicity allow for a wms request to be made for the layer in
>>>>> EPSG:900913 by setting the following in my MapServer LAYER:
>>>>> METADATA
>>>>> "wms_srs" "EPSG:4326 EPSG:900913"
>>>>> <snip...>
>>>>> 3. I define my TileCache layer so that it requests images from
>>>>> Mapserver in EPSG:900913.
>>>>> [v2_20m_global]
>>>>> type=MapServerLayer
>>>>> mapfile=/var/www/mapfiles/v2_20m_global/v2_20m_global.map
>>>>> metaTile=true
>>>>> metaSize=2,2
>>>>> metaBuffer=0,500
>>>>> layers=imagery
>>>>> srs=EPSG:900913
>>>>> That's what works for me.
>>>>> Roger
>>>>> On Thu, May 21, 2009 at 5:24 AM, Chad Clabaugh <cclabaugh at centwire.com>
>>>>> wrote:
>>>>>> Thank you Roger, for your response. I have done that but I do not
>>>>>> understand how tilecache works. The images that are returned from
>>>>>> mapserver
>>>>>> line up perfectly. But the images returned from tilecache do not align
>>>>>> very
>>>>>> well (they're distorted). If tilecache is simply caching the returned
>>>>>> images then I do not understand where this distortion comes from. Any
>>>>>> thoughts?
>>>>>> Thanks!
>>>>>> -----Original Message-----
>>>>>> From: Roger André [mailto:randre at gmail.com]
>>>>>> Sent: Wednesday, May 20, 2009 11:46 PM
>>>>>> To: Chad Clabaugh
>>>>>> Cc: mapserver-users at lists.osgeo.org
>>>>>> Subject: Re: [mapserver-users] Precache
>>>>>> Your request is somewhat lacking in detail, but assuming that your
>>>>>> goal is a simple one, here is one way to accomplish this.
>>>>>> 1. Create a MapServer project that displays your shapefile in whatever
>>>>>> style you choose.
>>>>>> 2. Setup a TileCache instance that points to your MapServer project.
>>>>>> 3. Run the tilecache_seed.py script to pre-generate tiles.
>>>>>> Roger
>>>>>> On Wed, May 20, 2009 at 12:16 PM, Chad Clabaugh
>>>>>> wrote:
>>>>>>> How can I precache tile images from shapefiles?
>>>>>>> Thanks
>>>>>>> Chad Clabaugh
>>>>>>> Technical Support, Engineering
>>>>>>> Office: 260.760.6398
>>>>>>> Mobile: 260.466.8861
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
