[mapserver-users] Mapserver CGI 5.4 crashed my app (Windows 2003)
Tamas Szekeres
szekerest at gmail.com
Mon Jun 22 11:47:46 EDT 2009
I had to replace the 'STATUS ON' with 'STATUS DEFAULT' in the mapfile to
make it work. Here is the result:
http://vbkto.dyndns.org:1280/cgi-bin4/mapserv.exe?map=E
:\tests\TestCGI\map.map&mode=map
But it seems the original problem couldn't be reproduced here, it might be
an environment specific issue (I'm using Win2003 x64).
I'll be trying to set up the same stuff in XP, just in case ....
Best regards,
Tamas
2009/6/22 stela anders <stelaanders at gmail.com>
> ok... I´m waiting for the news :p
> Thanks
> 2009/6/18 Tamas Szekeres <szekerest at gmail.com>
>> Hi,
>> I've set it up (Win2003) but didn't crash, though I get blank images in
>> cgi mode.
>> shp2img produces correct image however. I'm a bit uncertain whether the 2
>> problems are the same but I'll look into this one in more detail shortly.
>> Tamas
>> 2009/6/18 stela anders <stelaanders at gmail.com>
>>> Hi guys!
>>> I got that binary now :
>>> http://vbkto.dyndns.org:1280/sdk/release-1500-gdal-mapserver.zip
>>> Same error Tamas...
>>> System : Windows XP / IIS 5.1
>>> Using Postgis as datasourse...
>>> I made a package with :
>>> - Mapfile
>>> - Postgis data
>>> - Html
>>> You only need OL js to tryout...
>>> Or you can try typing :
>>> http://localhost/cgi-binx/mapserv.exe?map=map.map
>>> The error is :
>>> CGI Error
>>> The specified CGI application misbehaved by not returning a complete set
>>> of HTTP headers. The headers it did return are:
>>> Using version 5.2.2 all works fine...
>>> Stela
>>> Hi,
>>>> Some of the guys reported issues with mapserver 5.4+ in normal CGI mode
>>>> (FastCGI was reported ok) but I couldn't reproduce it myself so it would be
>>>> helpful if someone could describe the steps (and provide mapfiles/sample
>>>> data) to check it out.
>>>> You could also test with the binaries provided from here which appears
>>>> to be working ok.
>>>> http://vbkto.dyndns.org:1280/sdk/Default.aspx
>>>> Best regards,
>>>> Tamas
>>>>> Hey guys !
>>>>> That´s my first message here... (I´m from Argentina, sorry about my bad
>>>>> English)
>>>>> Is there any bug on Mapserver 5.4 CGI ?
>>>>> We have a full application using Mapserver 5.2 CGI on Windowns 2003/IIS
>>>>> ... We tried to update to newest version 5.4 and got a CGI error ...
>>>>> Is there any FAQ to upgrade ? Or maybe is it a bug?
>>>>> Stela
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090622/b5f22f2a/attachment.html
