[mapserver-users] Compiling MapServer
Thomas Bonfort
thomas.bonfort at camptocamp.com
Tue Jun 23 11:58:44 EDT 2009
Frank,
We already had a dependency on libpng and libjpg through GD (as gd
isn't statically linked against those). How can the direct dependency
be causing any more problems than the actual situation ?
regards,
thomas
www.camptocamp.com
+33 4 79 26 57 97
On Tue, Jun 23, 2009 at 17:50, Frank Warmerdam<warmerdam at pobox.com> wrote:
> Fawcett, David wrote:
>> What is the latest advice for output image libraries when compiling
>> mapserv on unix?
>> I remember an older conflict with libtiff and the tiff functionality in
>> GDAL.
>> If one is going to include GDAL, does it make sense to add libtiff,
>> libgeotiff, or libjpeg, or is it better practice to just use GDAL to
>> read and write these formats?
> David,
> It is better to leave out direct use of libtiff, and just let GDAL do it.
> Likewise for reading jpeg, and other image formats. However, I have
> noticed that mapserver-trunk now seems to depend on direct use of libpng
> and libjpeg for generating these files (as opposed to going through GD).
> So it may not be so easy to avoid libpng and libjpeg in builds.
> I persume this is not yet an issue with the released versions.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> mapserver-users at lists.osgeo.org
