[mapserver-users] WFS returning empty features
    DeDuikertjes
    DeDuikertjes at xs4all.nl
    Wed Jun 24 06:39:39 PDT 2009
Bart,
Thanks, Tried to widen that. No luck ..
Is the request ok (i try in the browser)? :
http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=geoidNL.IMRO.0026.SVBBU-0001_vlak
it returns:
<wfs:FeatureCollection xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd
http://mapserver.gis.umn.edu/mapserver
http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=geoidNL.IMRO.0026.SVBBU-0001_vlak&OUTPUTFORMAT=XMLSCHEMA">
<gml:boundedBy>
<gml:Box srsName="EPSG:28992">
<gml:coordinates>
155065.290000,467655.922000 156442.422000,470040.750000
</gml:coordinates>
</gml:Box>
</gml:boundedBy>
</wfs:FeatureCollection>
On closer inspection uDig does something strange. On zoom to layer it
zooms to the wrong area (but shows no features there either).
MArco
bartvde at osgis.nl schreef:
> Try and widen your MAP->EXTENT.
> Best regards,
> Bart
>> Roy, Jukka, List,
>> I've tried adding extents to each layer: no succes
>> I've
>> "gml_include_items" "all"
>> "gml_featureid"     "geoidn"
>> in the layer metadata
>> MArco
>> Here is a snippet of the mapfile:
>> MAP
>>     NAME "NL.IMRO.0026.SVBBU-0001"
>>     IMAGETYPE png
>>     UNITS METERS
>>     EXTENT 155016 467631 156758 470080
>>     PROJECTION
>>        "init=epsg:28992"
>>     END
>>     WEB
>>         METADATA
>>                 "ows_title"           "NL.IMRO.0026.SVBBU-0001"
>>                 "wms_onlineresource"
>> "http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&"
>>             "wfs_onlineresource"
>>             "wfs_srs"               "EPSG:28992"
>>             "wms_srs"               "EPSG:28992"
>>         END
>>     END
>> LAYER
>>     name "geoidNL.IMRO.0026.SVBBU-0001_vlak"
>>     GROUP "geoidNL.IMRO.0026.SVBBU-0001"
>>     PROJECTION
>>        "init=epsg:28992"
>>     END
>>     METADATA
>>         "ows_group_title"     "geoidNL.IMRO.0026.SVBBU-0001"
>>             "ows_title"           "geoidNL.IMRO.0026.SVBBU-0001_vlak"
>>         END
>>     STATUS off
>>     TYPE polygon
>>     DUMP true
>>     CONNECTIONTYPE postgis
>>     CONNECTION "host=localhost user=tc_check dbname=80.101.100.35"
>>     DATA 'tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using unique
>> geoidn using srid=28992'
>>     FILTER "geoidn='geoidNL.IMRO.0026.SVBBU-0001'"
>>     OPACITY 30
>>     TEMPLATE "dummy.html"
>>     CLASS
>>         STYLE
>>                 COLOR 0 0 0
>>                 OUTLINECOLOR 255 0 0
>>         END
>>     END
>> END
>> Rahkonen Jukka schreef:
>>> Hi,
>>> Do you have something in "gml_include_items" in the layer metadata?
>>> -Jukka Rahkonen-
>>> DeDuikertjes wrote:
>>> Roy, List,
>>> i'm using MapServer version 5.1-dev
>>> I've set the map extent. I did not set layer extents. Is that necessary?
>>> MArco
>>> Roy Braam schreef:
>>>> What  version of mapserver are you using? Have you set the map extent
>>>> and layer extents?
>>>> Roy
>>>>   _____
>>>> From: DeDuikertjes [mailto:DeDuikertjes at xs4all.nl]
>>>> To: mapserver-users at lists.osgeo.org
>>>> Sent: Wed, 24 Jun 2009 15:12:29 +0200
>>>> Subject: [mapserver-users] WFS returning empty features
>>>> Dear List,
>>>>   I've mapserver all set up.
>>>>   The mapfile is working and produces a nice and working WMS.
>>>>   The WFS is giving me troubles.
>>>>   It returns a valid capabilities document with no warnings
>>>>   A getfeature request returns GML, with the bounds defined, but
>>>> otherwise
>>>>   with NO features.
>>>>   This for a layer which draws perfectly well in the WMS.
>>>>   uDig sees all colums (attributes) of the layer, but every column is
>>>> empty.
>>>>   I've not a clue what I am doing wrong.
>>>>   any help greatly appreciated.
>>>>   MArco
>>>>   _______________________________________________
>>>>   mapserver-users mailing list
>>>>   http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
