[mapserver-users] WFS returning empty features
bartvde at osgis.nl
bartvde at osgis.nl
Wed Jun 24 09:28:36 EDT 2009
Try and widen your MAP->EXTENT.
Best regards,
Bart
> Roy, Jukka, List,
> I've tried adding extents to each layer: no succes
> I've
> "gml_include_items" "all"
> "gml_featureid" "geoidn"
> in the layer metadata
> MArco
> Here is a snippet of the mapfile:
> MAP
> NAME "NL.IMRO.0026.SVBBU-0001"
> IMAGETYPE png
> UNITS METERS
> EXTENT 155016 467631 156758 470080
> PROJECTION
> "init=epsg:28992"
> END
> WEB
> METADATA
> "ows_title" "NL.IMRO.0026.SVBBU-0001"
> "wms_onlineresource"
> "http://tercera-go.tercera-ro.nl/cgi-bin/mapserv?map=../html/plancheck_test/data/80.101.100.35_check/NL.IMRO.0026.SVBBU-0001/wkt/NL.IMRO.0026.SVBBU-0001.map&"
> "wfs_onlineresource"
> "wfs_srs" "EPSG:28992"
> "wms_srs" "EPSG:28992"
> END
> END
> LAYER
> name "geoidNL.IMRO.0026.SVBBU-0001_vlak"
> GROUP "geoidNL.IMRO.0026.SVBBU-0001"
> PROJECTION
> "init=epsg:28992"
> END
> METADATA
> "ows_group_title" "geoidNL.IMRO.0026.SVBBU-0001"
> "ows_title" "geoidNL.IMRO.0026.SVBBU-0001_vlak"
> END
> STATUS off
> TYPE polygon
> DUMP true
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost user=tc_check dbname=80.101.100.35"
> DATA 'tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using unique
> geoidn using srid=28992'
> FILTER "geoidn='geoidNL.IMRO.0026.SVBBU-0001'"
> OPACITY 30
> TEMPLATE "dummy.html"
> CLASS
> STYLE
> COLOR 0 0 0
> OUTLINECOLOR 255 0 0
> END
> END
> END
> Rahkonen Jukka schreef:
>> Hi,
>> Do you have something in "gml_include_items" in the layer metadata?
>> -Jukka Rahkonen-
>> DeDuikertjes wrote:
>> Roy, List,
>> i'm using MapServer version 5.1-dev
>> I've set the map extent. I did not set layer extents. Is that necessary?
>> MArco
>> Roy Braam schreef:
>>> What version of mapserver are you using? Have you set the map extent
>>> and layer extents?
>>> Roy
>>> _____
>>> From: DeDuikertjes [mailto:DeDuikertjes at xs4all.nl]
>>> To: mapserver-users at lists.osgeo.org
>>> Sent: Wed, 24 Jun 2009 15:12:29 +0200
>>> Subject: [mapserver-users] WFS returning empty features
>>> Dear List,
>>> I've mapserver all set up.
>>> The mapfile is working and produces a nice and working WMS.
>>> The WFS is giving me troubles.
>>> It returns a valid capabilities document with no warnings
>>> A getfeature request returns GML, with the bounds defined, but
>>> otherwise
>>> with NO features.
>>> This for a layer which draws perfectly well in the WMS.
>>> uDig sees all colums (attributes) of the layer, but every column is
>>> empty.
>>> I've not a clue what I am doing wrong.
>>> any help greatly appreciated.
>>> MArco
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
