[mapserver-users] PHP/Mapscript CLASS TEXT
Charlotte Declercq
c.declercq at alkante.com
Fri Jun 26 07:20:12 EDT 2009
Hello
I have an annotation layer on which I want to be able to draw labels.
Here is the layer :
LAYER
CLASSITEM "Id_BDCarto"
CONNECTION "Limites_administratives/Departement.TAB"
CONNECTIONTYPE OGR
LABELITEM "Nom_Département"
LABELMAXSCALEDENOM 1e+07
LABELMINSCALEDENOM 1990
METADATA
"LAYER_TITLE" "departement"
"GI_ARBO_ORDRE" "1"
"TYPE_SYMBO" "PROPORTIONAL"
"ECHELLE_LEGENDE" "ON"
"CLASS_LEGENDE" "ON"
END
NAME "layer2"
STATUS ON
SYMBOLSCALEDENOM 312411
TYPE ANNOTATION
UNITS METERS
CLASS
NAME "departement"
LABEL
ANGLE 0.000000
ANTIALIAS TRUE
FONT "Arial"
MAXSIZE 256
MINSIZE 4
SIZE 8
TYPE TRUETYPE
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 1 1
PARTIALS TRUE
POSITION CC
SHADOWCOLOR 0 0 0
SHADOWSIZE 0 0
END
STYLE
ANGLE 360
COLOR 232 246 9
OPACITY 100
SIZE [Id_BDCarto]
SYMBOL "Carre"
END
TEXT " "
END
END
With TEXT = " ", the layer is drawn without the labels. If TEXT property
is present, I am unable to draw the labels,
because I can't remove the TEXT property and I can't find a way to write
TEXT [attribute_name] with mapscript (do the binding as for example
$oStyle->setbinding(MS_STYLE_BINDING_SIZE, "FIELD_NAME")).
Anyone has solution :
- to remove the TEXT property ?
- to set the TEXT property with the attribute ?
Thanks,
Charlotte DECLERCQ
ALKANTE SAS
Ingénieur R&D SIG
1, rue du Chêne Morand
35 510 Cesson-Sévigné
Bur: + 33 (0) 2 99 22 25 70
fax : + 33 (0) 2 99 32 12 76
