[mapserver-users] getfeatureinfo problems
DeDuikertjes
DeDuikertjes at xs4all.nl
Fri Jun 26 07:29:02 EDT 2009
Dear list,
yesterday I reported problems with my WFS server. I could not fix that
up till now.
I have another possibly related problem.
My WMS is set up allright, getcapabilities is ok, I can see the map, pan
zoom, etc, no problems.
When I do an Identify (GetFeatureInfo request), I get back an
exception-report, with no items in (so essentially an ampty exception
report).
The query just doesn't seem to find the data.
Clicking inside a feature and outside does differ (outside doesn't give
an exception report).
I've enabled debugging and this is the output when I do a GetFeatureInfo
request:
[Fri Jun 26 13:21:11 2009].498623 CGI Request 1 on process 1525
[Fri Jun 26 13:21:11 2009].518710 msPOSTGISLayerOpen called datastatement: tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using unique geoidn using srid=28992
[Fri Jun 26 13:21:11 2009].518735 MSPOSTGISLayerOpen -- shared connection not available.
[Fri Jun 26 13:21:11 2009].523422 msConnPoolRegister(geoidNL.IMRO.0026.SVBBU-0001_vlak,host=localhost user=tc_check dbname=80.101.100.35,0x9457b38)
[Fri Jun 26 13:21:11 2009].523453 msPOSTGISLayerFreeItemInfo called
[Fri Jun 26 13:21:11 2009].523466 msPOSTGISLayerWhichShapes called
[Fri Jun 26 13:21:11 2009].523490 msPOSTGISLayerParseData: unique column = geoidn, srid='28992', geom_column_name = tc_vlak_geometry, table_name="NL.IMRO.0026.SVBBU-0001"
[Fri Jun 26 13:21:11 2009].523796 query_string_0_6:DECLARE mycursor BINARY CURSOR FOR SELECT asbinary(force_collection(force_2d(tc_vlak_geometry)),'NDR'),geoidn::text from "NL.IMRO.0026.SVBBU-0001" WHERE (geoidn='geoidNL.IMRO.0026.SVBBU-0001') and (tc_vlak_geometry && setSRID( 'BOX3D(155984.407968748 468982.233317728,156024.590926508 469022.416275488)'::BOX3D,28992) )
[Fri Jun 26 13:21:11 2009].535912 msPOSTGISLayerFreeItemInfo called
[Fri Jun 26 13:21:11 2009].535925 msPOSTGISLayerClose datastatement: tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using unique geoidn using srid=28992
[Fri Jun 26 13:21:11 2009].535931 msPOSTGISLayerClose -- closing query_result
[Fri Jun 26 13:21:11 2009].536007 msConnPoolRelease(geoidNL.IMRO.0026.SVBBU-0001_vlak,host=localhost user=tc_check dbname=80.101.100.35,0x9457b38)
[Fri Jun 26 13:21:11 2009].536017 msConnPoolClose(host=localhost user=tc_check dbname=80.101.100.35,0x9457b38)
[Fri Jun 26 13:21:11 2009].538905 msPOSTGISLayerOpen called datastatement: tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using unique geoidn using srid=28992
[Fri Jun 26 13:21:11 2009].538914 MSPOSTGISLayerOpen -- shared connection not available.
[Fri Jun 26 13:21:11 2009].543298 msConnPoolRegister(geoidNL.IMRO.0026.SVBBU-0001_vlak,host=localhost user=tc_check dbname=80.101.100.35,0x9457b38)
[Fri Jun 26 13:21:11 2009].543314 msPOSTGISLayerFreeItemInfo called
[Fri Jun 26 13:21:11 2009].543319 in msPOSTGISLayerGetItems (find column names)
[Fri Jun 26 13:21:11 2009].543329 msPOSTGISLayerParseData: unique column = geoidn, srid='28992', geom_column_name = tc_vlak_geometry, table_name="NL.IMRO.0026.SVBBU-0001"
[Fri Jun 26 13:21:11 2009].545217 msPOSTGISLayerInitItemInfo called
[Fri Jun 26 13:21:11 2009].545230 msPOSTGISLayerGetShape called for record = 0
[Fri Jun 26 13:21:11 2009].545239 msPOSTGISLayerParseData: unique column = geoidn, srid='28992', geom_column_name = tc_vlak_geometry, table_name="NL.IMRO.0026.SVBBU-0001"
[Fri Jun 26 13:21:11 2009].545253 msPOSTGISLayerGetShape: DECLARE mycursor2 BINARY CURSOR FOR SELECT "geoidn"::text,"idealisatie"::text,"tc_multi_geometry"::text,"tc_lijn_geometry"::text,"tc_punt_geometry"::text,asbinary(force_collection(force_2d(tc_vlak_geometry)),'NDR') from "NL.IMRO.0026.SVBBU-0001" WHERE geoidn = 0
[Fri Jun 26 13:21:11 2009].547105 msFreeMap(): freeing map at 0x943d518.
[Fri Jun 26 13:21:11 2009].547114 msPOSTGISLayerClose datastatement: tc_vlak_geometry from "NL.IMRO.0026.SVBBU-0001" using unique geoidn using srid=28992
[Fri Jun 26 13:21:11 2009].547119 msPOSTGISLayerClose -- query_result is NULL
[Fri Jun 26 13:21:11 2009].547124 msConnPoolRelease(geoidNL.IMRO.0026.SVBBU-0001_vlak,host=localhost user=tc_check dbname=80.101.100.35,0x9457b38)
Just as with the WFS problem, there is no data returning. The WFS does show the exposed columns, never any data in.
I've not a clue of how to proceed, or how to get extra debug info.
Please help !
MArco
[Fri Jun 26 13:21:11 2009].547132 msConnPoolClose(host=localhost user=tc_check dbname=80.101.100.35,0x9457b38)
