[mapserver-users] getfeatureinfo problems
David Nugent
davidn at datalinktech.com.au
Fri Jun 26 20:01:14 EDT 2009
On 26/6/09 11:10 PM, Bart van den Eijnden (OSGIS) wrote:
> Mapserver needs an integer type column for the USING UNIQUE clause, not
> a string column. That won't work.
Actually, no it doesn't require an integer type column for the UNIQUE
clause. I have used text fields in the past with mapserver 5.x and can
confirm that it does indeed work.
Mind you, some other cartographic software such as QGIS does insist on
int4 fields for PostGIS layers, but not mapserver.
Regards,
David
