[mapserver-users] Grave performance issue with MapServer and
GDAL/OCI driver
Smith, Michael ERDC-CRREL-NH
michael.smith at usace.army.mil
Mon Jun 29 12:06:20 EDT 2009
You can also try using the Mapserver direct Oracle connection rather than
going through OGR.
LAYER
NAME "aree_stradali"
STATUS DEFAULT
TYPE POLYGON
# Dati da connessione Oracle
CONNECTIONTYPE ORACLESPATIAL
CONNECTION "username/secret at localhost/sitfi02t"
DATA "SPATIAL_COLUMN FROM REPLICA_TOPONOMASTICA.AGGR_AREESTRADA USING
UNIQUE OBJECTID"
# Dati da shapefile
#DATA "shape/toponomastica/aree_strada.shp"
PROJECTION
"init=epsg:3003"
END
DUMP TRUE
METADATA
"wfs_title" "aree_stradali"
"gml_featureid" "objectid"
END
CLASS
STYLE
COLOR 255 0 0
WIDTH 1
END
END
END
On 6/29/09 10:51 AM, "Frank Warmerdam" <warmerdam at pobox.com> wrote:
> Niccolo Rigacci wrote:
>> I experienced a severe performance problem with MapServer
>> configured as WFS server, taking data from Oracle via GDAL/OCI
>> driver.
>> All the features take about 9.6 Mb of xml data (via WFS) or 8.4
>> Mb of text data (via ogrinfo).
>> Retrieving all the features via WFS from a shapefile takes less
>> than one second, retrieving the same WFS from Oracle takes about
>> 470 seconds. Retrieving data via the ogrinfo utility takes about
>> 3 seconds:
>> Tests are performed from the same Linux box, taking data in this
>> way:
>> 1 s: wget <- http <- Remote_host <- MapServer <- GDAL <- shapefile
>> 470 s: wget <- http <- Remote_host <- MapServer <- GDAL/OCI <- localhost <-
>> Oracle
>> 3 s: ogrinfo <- GDAL/OCI <- Remote_host <- Oracle
>> It seems that wget (int the Oracle case) starts at about 400
>> Kb/sec transfer rate, then it drops down to 13 Kb/sec a few
>> seconds later.
>> Does somebody have any idea where is the bottleneck? How can I
>> debug such slodown?
> Niccolo,
> This is almost certainly due to the two-pass query approach in mapserver.
> On the first pass the id's of all features matching the query are collected
> and then the features are fetched, one by one, by id. In the case of the
> oci driver in OGR a fetch by id issues an sql select statement. So you are
> basically getting one sql select statement per features which is very
> inefficient.
> What you need if you want to do large amounts of feature query - such as for
> WFS - is the new one pass query mechanism that Steve is working on. I'm not
> exactly clear on it's status.
> Note that this two pass query anti-optimization does not affect feature
> drawing which is accomplished in one pass. It also does not significantly
> affect formats like shape where fetching by id's has no noticable overhead.
> Best regards,
