[mapserver-users] Dynamic LabelItem
stretch
andrew.deklerk at gmail.com
Tue Jun 30 12:30:44 EDT 2009
I know, and I want all that new functionality :)
I am using 5.0.0
I did try an upgrade a couple of weeks ago, but we had hassles with existing
application running with openlayers as the frontend, where it displayed the
the whole map file image in each map tile as opposed to cutting it up (if
that makes sense!). also, our getLegendGraphic requests didnt work after the
upgrade. We therefore quickly restored back to 5.0.0.
The straight mapserv request was working fine, so it is more a openlayers
issue - however - we could not go through and sort out all our existing
apps, so thats why we downgraded again. I have just downloaded the 5.4.1
beta MS4W from maptools and will try that tonight, and see If i can get my
openlayers resolutions correct
Andrew
Steve Lime wrote:
> That particular portion of MapServer has undergone a lot of change. At
> first I removed too much
> functionality in 5.0, then exposed a bit more in 5.2 and probably got a
> lot closer to "right" in 5.4.
> You're safest with 5.4.1 if you can afford to upgrade. What version
> exactly are you using?
> Steve
>>>> On 6/29/2009 at 2:13 PM, in message
>>>> <1246302809284-3176452.post at n2.nabble.com>,
> stretch <andrew.deklerk at gmail.com> wrote:
>> ok - thanks for the response. If I try
>> &map.layer[Compartments]=labelitem%20Age
>> i get
>> getSymbol(): Symbol definition error. Parsing error near ():(line 1)
>> I am using Mapserver 5, I guess I should be using 5.4?? If that is the
>> case,
>> is there a solution I could use with version 5 or will I need to upgrade
>> Thanks
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Dynamic-LabelItem-tp3174574p3183671.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
