[mapserver-users] plotting points dynamically
Suman Chatterjee
schatterjee at addisontx.gov
Tue Jun 30 10:58:12 EDT 2009
Hi all,
I am working on a project which requires adding points to a basic map
dynamically. That means the basic map will be read from the map file.
Then the points will be queried from a database preferably PostGreSQL
and then plotted on the map. I cannot add the query to the map file
because the points will be generated dynamically at regular intervals.
Is there any way I can do this in mapserver?
This e-mail and any files or attachments transmitted with it contains Information that is confidential and privileged. This document may contain Protected Health Information (PHI) or other information that is intended only for the use of the individual(s) and entity(ies) to whom it is addressed. If you are the intended recipient, further disclosures are prohibited without proper authorization. If you are not the intended recipient, any disclosure, copying, printing, or use of this information is strictly prohibited and possibly a violation of federal or state law and regulations. If you have received this information in error, please delete it and notify Hamid Khaleghipour at 972-450-2868 immediately. Thank you.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090630/f4a591ee/attachment-0001.html
