[mapserver-users] R: PHP Mapscript - Displaying only image
colour except the existing layers
zizu
manojkapil06 at gmail.com
Tue May 5 09:31:39 EDT 2009
Hi pietro,
Thank you so much... now its works fine......
On Tue, May 5, 2009 at 6:07 PM, Pietro Giannini (via Nabble) <
ml-user+94644-1894679202 at n2.nabble.com<ml-user%2B94644-1894679202 at n2.nabble.com>
> wrote:
> Hi Zizu,
> STATUS OFF on all the layers of your map.
> To turn on:
> $layer = $map->getLayerByName('kerala');
> $layer->set('status', MS_ON);
> $image=$map->draw();
> $image_url=$image->saveWebImage();
> bye
> ...................pg
> ________________________________________
> Da: mapserver-users-bounces at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=0>[
> mapserver-users-bounces at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=1>]
> per conto di zizu [manojkapil06 at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=2>]
> Inviato: martedì 5 maggio 2009 12.59
> A: mapserver-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=3>
> Oggetto: [mapserver-users] PHP Mapscript - Displaying only image colour
> Dear users,
> I am using FGS-Mapserver, its a stand alone environment on fedora 9. i have
> successfully play mapserver through cgi, there is absolutely no problem
> with
> that. Now am trying to play PHP-Mapscript , example given in the tutorial.
> The problem am encountering right now is when i run the php file through
> browser
> http://localhost:8080/mapfiles/sampletest/htdocs/test.php
> Luckily the image colour of the map is displaying but the layers of the map
> is not displaying... herewith am attaching the screen shot of that
> page....
> am also attaching both the map file and php file for your view.....
> what could be a problem..... please help me out..
> tips will be appreciated....
> http://n2.nabble.com/file/n2792269/Screenshot.png Screenshot.png
> http://n2.nabble.com/file/n2792269/test.map test.map
> http://n2.nabble.com/file/n2792269/test.php test.php
> many thanks,
> zizu
> http://n2.nabble.com/PHP-Mapscript---Displaying-only-image-colour-except-the-existing-layers-tp2792269p2792269.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=4>
> mapserver-users at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2793318&i=5>
> This email is a reply to your post @
> http://n2.nabble.com/PHP-Mapscript---Displaying-only-image-colour-except-the-existing-layers-tp2792269p2793318.html
> You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/PHP-Mapscript---Displaying-only-image-colour-except-the-existing-layers-tp2792269p2794721.html
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090505/04966bd6/attachment-0001.html
