[mapserver-users] MapServer 5.4 WMS Server VERSION=1.3.0 Problem
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue May 5 11:21:00 EDT 2009
Ben Madin wrote:
> G'day Assefa,
> On 05/05/2009, at 12:16 AM, Yewondwossen Assefa wrote:
>> Do you have the full URL that is received by the server?
> No... I'm not sure how to get this(?) - I thought it might be shown if I
> set the debug levels high enough, but so far no luck!
If you have access to the web server you can check the logs (with
Apache, it would be the access.log that would contain the request)
You can also get it in your browser by checking the URL referenced by
the image.
>> MapServer WMS 1.3.0 supports the following EXCEPTIONS : XML, INIMAGE,
>> or BLANK.
>> Is might be possible to add EXCEPTIONS: "XML" (or INIMAGE, or
>> BLANK) when building your OL wms 1.3.0 layer?
> using either :
> new OpenLayers.Layer.WMS( 'Countries',
> 'http://trade.murdoch.local/cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/layers/ol_countries_wms.map&SERVICE=WMS&VERSION=1.3.0&EXCEPTIONS=INIMAGE&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&',
> {layers: 'countries'} );
> or
> new OpenLayers.Layer.WMS( 'Tail Tag Areas',
> 'http://trade.murdoch.local/cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/layers/ol_countries_wms.map&SERVICE=WMS&REQUEST=GetMap&STYLES=&SRS=EPSG:4326',
> {layers: 'tailtagareas', transparent: 'true', version:
> '1.3.0', exceptions: 'xml'} );
As I understand it, Openlayers (at least version 2.7) does not support
wms 1.3.0. But you can still do the following and use CRS:84 in your case:
var options2 = {
maxExtent: new OpenLayers.Bounds(-180, -90, 180, 90),
units: 'degree',
//projection: "EPSG:4326"
projection: "CRS:84"
map = new OpenLayers.Map( 'map', options2 );
layer = new OpenLayers.Layer.WMS( "gmap wms",
"http://127.0.0.1:8080/cgi-bin/mapserv.exe?map=f:/msapps/gmap-ms40/htdocs/gmap75_wms_4326.map",
{layers: 'DEMO', VERSION:'1.3.0', EXCEPTIONS:'INIMAGE', CRS:'CRS:84'} );
map.addLayer(layer);
> gives no error, but neither do I receive any images any more.
> using the url (such as in the first example) works fine in QGIS, so I'm
> guessing the web serving 'can' work... very confusing.
I think QGIS does support wms 1.3.0. At the end what the GetMap
parameters should be is:
...&CRS=EPSG:4326&BBOX=ymin,xmin,ymax,xmax or
...&CRS=CRS:84&BBOX=xmin,ymin,xmax,ymax
Best regards,
> cheers
> Ben
>> Ben Madin wrote:
>>> G'day all,
>>> I'm a little new to WMS, but I confess the GetLegendGraphic feature
>>> available now in the 5.4 release caught my eye.
>>> So I'm 5.4.0 and using OpenLayers 2.7. However, when I use the URL :
>>> /cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/layers/ol_countries_wms.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&
>>> I get the following message (embedded in the tile) :
>>> msWMSLoadGetMapParams(): WMS server error. Invalid format for the
>>> EXCEPTION parameter.
>>> If I drop the VERSION (either back to 1.1.1 or just completely loose
>>> it, text below in the context of the OL script.
>>> var pol_bnd = new OpenLayers.Layer.WMS(
>>> 'Countries',
>>> 'http://trade.murdoch.local/cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/layers/ol_countries_wms.map&SERVICE=WMS&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&',
>>> map.addLayer(pol_bnd);
>>> I get my maps.
>>> I can work with this for now, but is there something I'm missing. I
>>> did try fiddling with the reported CRS / SRS changes, but I think I
>>> just confused myself - but that would be another topic!
>>> Perhaps along with the mapfile in the documentation, a copy of a full
>>> example of a request url would be great.
>>> Some of the mapfile is attached for completeness (it has been sucked
>>> across from a CGI Mapserv application):
>>> MAP
>>> NAME aus_boundaries
>>> STATUS ON
>>> UNITS DD
>>> EXTENT 110 -35 130 -12 # WA extents
>>> SIZE 900 650
>>> SHAPEPATH "../geodata/"
>>> FONTSET "../geodata/fonts/fonts.lst"
>>> SYMBOLSET "../trade.sym"
>>> IMAGECOLOR 230 240 255
>>> CONFIG "MS_ERRORFILE" "/var/log/mserr.log"
>>> DEBUG 5
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> WEB
>>> METADATA
>>> "wms_title" "GMS Livestock Trade"
>>> "wms_onlineresource"
>>> "http://trade.murdoch.local/cgi-bin/mapserv?map=/Users/19022662/Sites/marketprices/mapserver/ol_countries_wms.map&"
>>> "wms_srs" "EPSG:4326"
>>> END
>>> IMAGEPATH "../../tmp/"
>>> IMAGEURL "../../tmp/"
>>> END
>>> LAYER
>>> METADATA
>>> "wms_title" "Country Boundaries"
>>> "wms_group_title" "Political"
>>> END
>>> STATUS ON
>>> NAME "countries"
>>> GROUP "Political"
>>> DATA "global/ctybnda"
>>> TYPE polygon
>>> OPACITY 100
>>> CLASS
>>> NAME "Country Borders"
>>> COLOR 240 240 180
>>> OUTLINECOLOR 0 70 0
>>> END
>>> END
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
