[mapserver-users] UMN and SVG output
Daniel Morissette
dmorissette at mapgears.com
Thu May 14 04:02:42 PDT 2009
Till Adams wrote:
> Dear list,
> we have a problem with (old but working) Mapserver 4.10 version and svg
> output transparency:
> On one system (solaris 10) everything works fine.
> On the other system (solaris 10) with exactly the same mapfile, the
> originally as transparent defined polygons
> (COLOR -1 -1 -1) come out in black.
> I guess that GD library is responsible for creating the SVG. Did anybody
> had this problem before or does anybody have an idea which component may
> cause this error?
Till,
Did you really mean SVG? SVG is a vector format which is rendered by the
browser, are you using the same browser to access both servers?
I'd suggest you start by comparing the SVG output from both to try to
figure the difference (it's XML-ish) between the output from your two
servers, and then we can go from there.
Daniel
Daniel Morissette
http://www.mapgears.com/
More information about the MapServer-users
