[mapserver-users] UMN and SVG output
Daniel Morissette
dmorissette at mapgears.com
Fri May 15 05:27:46 EDT 2009
Till Adams wrote:
> Daniel,
> firstr of all many thanks for your reply, we already did that:
> The upper is the SVG code comes from the mapserver, where the SVG
> appears in black, the lower one is the correct one. The differene
> between the files is the style definition ' style="fill: none;" ' which
> is missing in the upper SVG. Both mapservers are 4.10, are compiled with
> the flag "--with-svg" and use exactly the same mapfile.... could it be
> that there are any differences in the linked GD library or the
> uinterface beteen UMN and GD ...?
Ha! Found it!
This was an issue in early 4.10.x versions that was fixed in 4.10.2:
http://trac.osgeo.org/mapserver/ticket/2055
You probably have 4.10.0 or 4.10.1 on one machine, and 4.10.2 or more
recent on the other.
Daniel
Daniel Morissette
http://www.mapgears.com/
