[mapserver-users] PHP Mapscript - Displaying only image colour
except the existing layers
Daniel Morissette
dmorissette at mapgears.com
Thu May 14 10:25:21 EDT 2009
kapil manoj wrote:
> i have received the following error after changing the status of the
> layers to both DEFAULT or ON
> Warning: [MapServer Error]: msGetLabelSize(): Requested font
> (arial-bold) not found. in
> /home/kapil/FGS-MAPSERVER/www/htdocs/mapfiles/sampletest/htdocs/test.php
> on line 6
If you haven't solved this already, then I'd suggest you make sure font
"arial-bold" is defined in your fontset and that the path to the
corresponding TTF file is valid.
Daniel
Daniel Morissette
http://www.mapgears.com/
